Geico "In Stock" date
Hi Keith,
If your DX2 has a boat logo on it near the car, then you can use your existing tx. If it doesn't you need to change either the rx or the tx. I strongly recommend you get a Marine-compatible transmitter so that you can use it on the water reliably. The Marine radios have a long antenna lead, but only the last inch or so is "active" antenna - the rest is just a cable to allow you to position it properly.
You don't need to change your receivers if you get the DX3S. It still works just fine with the SR-type receivers. It supports both Marine and Surface protocols.
AndySpektrum Development TeamComment
Guys... if you want a less expensive, but equally as effective, Spektrum radio setup, look into the DX3E as well. Not all the bells and whistles of the DX3S, but nicely priced and same performance.Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Just to clarify,
1. can the unused wire be coiled and tie wrapped inside the hull?
2. how high does the last inch or so have to extend? Is higher better?Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
The unused wire can be coiled, but NO SMALLER THAN 2" DIA COIL! Otherwise it breaks internally and it's not fun (especially in an airplane, don't ask how).
The higher the better for the active portion. We made the antenna as long as we did because I needed it that long for my Sport and rigger hulls to get it out. Also, it works best when that portion is vertical.
I have one on order @ LHS!!! I cant wait.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
Your order was submitted 8/25/2010 7:45:36 PM
Ugh just blew that money right before school..... god help meComment
you guys are bad influences... according to you every boat is a good boat... that's way I've purchased 4 boats during this summer.... and now 5 after this baby comes in. how addicted am I already?Comment
I still use my old banged up DX2. I would like to upgrade my receivers to the marine versions but rx's + a DX3S is a pretty heavy bill
