BJ 29 v3 running hot help
  • boatsrnew2me
    • Oct 2016
    • 476
    my bj29 v3 runs kinda hot . stock setup here with a cnc x440/3 blade prop .timing 7.5
    first run was with 5500 mah lipos mid tray , top speed 49.1 . motor temp 170 esc 130ish.
    second run 5000 mah all the way back in trays (lighter lipos too) motor temp 150 esc 100-110ish .top speed 51.4
    strut is level with sponsons with boat sitting on table .
    should i raise the strut? can you tell by my running video if its running too wet?
    volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
  • Erroneous
    • Apr 2016
    • 451
    Raise strut to 1/8" above the table ( I run mine at a slight negative angle ). One prop blade should be in the water when at speed.
    • ray schrauwen
      • 9471
      4S or 6S?
      Nortavlag Bulc
      • boatsrnew2me
        • Oct 2016
        • 476
        running 6s
          • 8012
          Gotta be 6S with that prop and stock motor to get those speeds. What ESC? The motor is likely now damaged with those temps if done often...
          • ray schrauwen
            • 9471
            I was going to say motor life going south quick too at that temp.
            Nortavlag Bulc
            • boatsrnew2me
              • Oct 2016
              • 476
              everything stock cept the prop . i dont run it like this all the time ,at this temp . i should be able to get the temp down . second run was only a 2 minute run ,i was being more cautious because of the first run temps
              • Erroneous
                • Apr 2016
                • 451
                I never did like the stock setup. Was it fast, yes. Did everything run hot (even the ec5 connectors), YES. Changed out all the guts pretty quick to Seaking180/leopard 4074. Ran faster, smoother and alot cooler (even the ec5 connectors). Try a 2 blade prop in the 43mm range with the strut raised and the packs to the back. Motor still smoking, I would have no trust in it. Like Fluid said the motor could be scorched.
                • boatsrnew2me
                  • Oct 2016
                  • 476
                  i raised the strut 2mm hope to get a run in thursday if the weather is better . yes i have read things run hot with this boat .but its still new ,i have no desire to change anything yet .i will update my findings
                  • boatsrnew2me
                    • Oct 2016
                    • 476
                    raised my strut about 2mm ,went for a run . lost about 2 mph and temps werent any better ,after 4-5 passes and maybe 2 minutes max motor was again 170 coming in . esc wasnt too bad 130 max.
                    anyway ,i am going to put the strut back where i started and start looking for other ways to get the temps down .
                    what if i go the other way with the strut?
                    check my pics ,the first line is where i started and you can see its raised up about 2mm. i scribed the strut with a razor knife so i can see where i started and where i been .
                    anyone ever use a transom pickup for water cooling on these boats? for now i will start drilling the water openings open in the rudder, the top of rudder nipple ,ect,ect....
                    • fweasel
                      master of some
                      • Jul 2016
                      • 4285
                      I've said it a number of times before, your cooling lines are plumbed wrong.
                      Vac-U-Tug Jr (13mph)
                      • boatsrnew2me
                        • Oct 2016
                        • 476
                        line goes to motor first ,thats where i need the most cooling . if i were to turn the cooler to get water to enter at bottom the top nipple would be straight up and not allow me to close the hatch .
                        what are you suggesting?
                        what were your temps when you ran the x440/3?
                        • ray schrauwen
                          • 9471
                          Do you always run the drive dog that close to the strut? You need at least 4mm gap there. That can heat things up.
                          Nortavlag Bulc
                          • boatsrnew2me
                            • Oct 2016
                            • 476
                            no i usually dont ,looks like i did today eh?
                            i will open up the gap .someone else noticed my rudder was not 90 degrees and i have corrected that now as well . are these washers between the drive dog and strut even needed ? i could take those out and have a nice gap there . it came with them out the box .
                            i worry if i open the gap too much there wont be enough flex shaft in the collet .removing the washers would take care of that .
                            i also put my strut back where it was during my best run . Rafael noticed something with my prop too which i have corrected now .
                            • boatsrnew2me
                              • Oct 2016
                              • 476
                              update ....
                              i straightened out the rudder ,it was pitched inward a little before .
                              i removed the plastic washers at the drive dog'
                              i drilled out the rudder water inlets and the nipple on top the rudder
                              left bigger gap between strut and drive dog .
                              i smoothed out the leading edges of the prop ,Rafael noticed it was kind of blunt .(good eye ,thanks)
                              last run i did was near 50 mph and temps were down to 135 motor and 110 esc .
                              i have since then also drilled out the water outlet to a larger size . will be taking a test run today .
