29 V3 best stock prop
  • dtacmed
    • Mar 2008
    • 199
    Any new recommended best prop for a stock 4s setup with the stock motor.
  • Blevins
    • Feb 2014
    • 20
    X642 will do well on some good 2 cell lipos.
    BlackJack-Miss Geico 29 V3 Leopard 4074 2200KV 78mph on GPS so far- FE Fun boat
    JAE 21GT B Hydro outrigger, Whiplash B Sport Hydro-Nitro Race Boats District-14
    www.ABMods.com
    • fweasel
      master of some
      • Jul 2016
      • 4285
      I ran the x642 on 4s and ran 49mph all day long on the V3. It does run warm, so I would be sure to reroute your stock cooling lines: rudder>ESC>Motor lower barb>motor upper barb>hull outlet
      Vac-U-Tug Jr (13mph)
      • Fixitguy1
        • Nov 2016
        • 45
        I have a Miss Geico V3 29 and plan to run on 6s 5200mah 45c what prop would you recommend been thinking of a 440/3 just a guess
        Any ideas
        • fweasel
          master of some
          • Jul 2016
          • 4285
          Any ideas
          I ran a sharpened and balanced X440/3 prop on stock electronics with two 3S graphene packs and did 60mph consistently. The motor runs warm, so I rerouted the cooling lines to feed the motor first, then the ESC, opposite of my slower 6S setups. You also need to lower the stock ESC timing from 15* to 7.5* to use that prop, per Rafael at Proboat.
          • Fixitguy1
            • Nov 2016
            • 45
            I noticed that the sponsons are pretty bad and plan to blueprint them, should I also include the flat part of the hull
            Thanks for your input on cooling. Have a lot of work to do
            • Erroneous
              • Apr 2016
              • 451
              You only need to blueprint the sponsons. The newer V3 hulls (with white epoxy inside) are near perfect though.
              • Fixitguy1
                • Nov 2016
                • 45
                At first glance the boat looks good, then I had it on my desk in the sun and the deck had some waves in it and when I checked the sponsons they where just as bad.
                It is the newer MG V3 hull. my friend has one also and have not checked it out yet, will tomorrow.
                Thanks
                • Erroneous
                  • Apr 2016
                  • 451
