Bushing would not be inside strut question, how long is the flex on miss geico 29 v2?
  • waterproof
    • Jul 2013
    • 239
    Hello.
    When i pulled out my flex shaft yesterday it was a loose wire and when i drag it out it took also with the plastic tube and this things called bushing? When i push the bushing in to the strut it came littlebit out after a run. The boat have only been used 4-5 times, also hear a low whistle sound from the boat when i run it. Could that be the bushing?
    No bearings? Just the two parts on the pics?
    I found out that i just could bend inside the bushing and get it tight.
    Where could i order a stock bushing to have as a sparepart?
    I should also have a new flex shaft for my blackjack 29 v3 but no one have it, the shaft is 33cm, anyone know if the miss geico v2 shaft would fit right on?
  • waterproof
    • Jul 2013
    • 239
    Could only find bushing for the impulse 26 online, is that the same?
    Where could i buy new bushing for blackjack v3?
      • 7673
      I'll look thru my parts tomorrow for you. I have some old PB stuff there
      • waterproof
        • Jul 2013
        • 239
        That would be nice if you check the bushing.
        I just find out that the flex shaft from miss geico 29 have the same lenght as the blackjack 29 v3.
        Every store is sold out online, and if they just know that they are the same many more could order them.
          • 7673
          I looked at my parts and both the struts I have are pooched. Sorry buddy.
          • waterproof
            • Jul 2013
            • 239
            Thank you for your time to look for it :-)
            No one know where i could order a original bushing?
