not sure
  • jlr3rd1
    • 240
    not sure
    first run with lipos, in my blackjack?? the boat went about half way round the lake and stoped?? when you squeeze the trigger you could hear the motor turning but no power, barley got back to shore:) when i opened the hatch there was a lilttle smoke around the left battery plug???? but out of the water the motor turns fine???
    2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
    • 8012
    First a few questions, then we can help:
    - Did the BJ run okay with NiMH cells?
    - Are the BJ motor and ESC the same as came the factory?
    - How many LiPo cells and how are they wired (4S1P, 6S2P)?
    - What charger did you use to charge the LiPos?
    - What plugs are you using between the LiPos and the ESC?
    - How is the LVC set?
    • jlr3rd1
      • 240
      ok yes it ran fine on the nimh batts? and the motor and esc are the stock ones, my batts 2 cell 7.4v 3700 zippys . my charger is a i charger ic6 ,and useing dean leads?
      • jlr3rd1
        • 240
        well after checking a few things the collector nut at the flex shaft LOSE BUT STILL NOT SURE WHY THE SMOKE???
        • jlr3rd1
          • 240
          Help
          i need help my blackjack 26 flex shaft keep s slipping, i can tighten the two nuts and the shaft is tight. after about 5 seconds in the water the shaft starts slipping and the boat wont go?? could the shaft be striped or what is going on??
          • domwilson
            Moderator
            • 4408
            Try solder/resolder the flex shaft. About 3/4" of inch.
            The side that slides into the collet.
            Government Moto:
            • jlr3rd1
              • 240
              thks :) but now the two nuts are stripped.they wont tighten down, it gets some what tight and the turns LOSE AGAIN?? BUT WHEN IT DID RUN ON THE LIPOS ,WOW CRAZY FAST:)
              • animigan
                • Jun 2009
                • 71
                jlr, there are two threads a few pages back addressing the loose/broken/sucky stock collet nut. I have used both the octura 5mm to 0.150 (short) collet as well a three piece one from Kintec racing (it's a tight fit, but really nice too). There are links to those products as well as helpful comments from the senior members that might help you out! One thing i learned quick was to make sure i didn't get any marine grease on the proximal tip of the flex shaft to help the collet grip. Hope that helps!
                Andre
                • jlr3rd1
                  • 240
                  yes it does thks:)
