Upgrading to 5S, need some help.
  • Eggy
    • Jun 2009
    • 152
    Hello, im thinking about upgrading my stock BJ to 5S, an need some help.
    I'm thinking about ordering a Rhino 2S 3700Mah 25C and a Rhino 3S 3700Mah 25C.
    - Since i'm new to the FE hobby i need some help, is there anything more i need?
    - Since the Low Voltage cutoff on the standard ESC is setup to 4S this wont help me. How do normaly do the driving with 5S on a BJ safe without damaging the lipos? Wil this help me or is it no need for it?
    - Also hear something about a BEC, is this something i need to buy or??
    Thnx guys, your help so far have been great.
  • Christaphason
    • Jun 2009
    • 104
    Id recommend running either an external BEC or a receiver pack, you can get a BEC here on OSE
    http://www.offshoreelectrics.com/pro...cas-castle-bec
    At the moment it is out of stock.
    To use the external BEC you MUST cut the red wire from you speed control that connects to the receiver. You can install the BEC by soldering the wires from the BEC to the red and black wires coming from you speed control. Then all you do is plug you External BEC into the reciever and you good to go. You do not have to actually CUT the wire you can simply slip it out of the servo plug and put heat shrink over it, which will allow you to go back to using the stock setup easier. Just wanted to make that clear before you go hacking at the ESC
    You can avoid all the soldering(which isnt really much) and run a receiver pack by again CUTTING the RED WIRE coming from you ESC to your receiver and getting something like this
    http://www.offshoreelectrics.com/pro...p?prod=dh-3170
    or, an option that may be more practical and save money in the long run
    Side note, I have not personally run 5s on the stock speed control but i have heard of people doing it, i would recommend definitely running some type of BEC or receiver pack though.
    Hope i helped
    --Chris
    • Eggy
      • Jun 2009
      • 152
      Ok. Could someone shortly and easy tell me what the point of the BEC and the Reciver pack is?
      • kookie_guy
        • Jun 2008
        • 897
        BEC = battery eliminator circuit. The ESC from the factory has one built in. It takes your supply voltage from the batteries, and limits it down to 6volts (operating voltage of receiver and servos). If you increase the supply voltage, the built in BEC might not be able to handle it, and you'll see the magic smoke (not good).
        Running a receiver pack essentially takes out the magic smoke cause. But you MUST remove the red wire from the ESC receiver plug. If you don't, you will have 6volts from your receiver pack, and 6 volts from your BEC, and again, magic smoke.
        Hope that helps.
        • Eggy
          • Jun 2009
          • 152
          Ah, that makes it alot clearer. What is the max Voltage that the Reciver and the Servo can run on. Thinking about using a small 2S lipo to power the reciver and servo, would this work? Alot cheaper over time and alot neater.
          • kookie_guy
            • Jun 2008
            • 897
            2s is too much. 4.8-6volts. You want 6 because you get more torque out of the servo. It can be very clean, just get one of those holders for 4 AA batteries. 4 AA alkaline batteries will give you 6 volts. Rechargeable AA's will give you 4.8 (when using 4) because they are 1.2volts, not 1.5 like alkalines.
            • Eggy
              • Jun 2009
              • 152
              Ok, think i will use a 5C Nimh Reciver pack, and make room for is somewhere. That way i dont have to buy new AA's all the time. How many mah do i need for the servo and reciver. Will 2000Mah do it for 1hour of runtime? Think i read somewhere that the max was 1A so 2000mah should be more than enough.
              • kookie_guy
                • Jun 2008
                • 897
                that's plenty
                • BIGDG357
                  • 243
                  only my opinion but the castle creation bec is only $23 at OSE and its tiny and should be no problem to store it away neatly and you dont have to worry about extra batteries at all
                  • Eggy
                    • Jun 2009
                    • 152
                    The only thing keeping me from going for that is that its out of stock. I have my salry coming in within a day or two, and then placing an order at OSE and HC. If someone could find an external BEC that will work and that is in stock i may be considering it.
                    • BIGDG357
                      • 243
                      yeah that was my problem too i just made an OSE order and was short of only the bec.I got mine on Ebay .Just search castle creations bec there are quite a few there
                      • mtk
                        • Jun 2009
                        • 58
                        Don't get the castle creations bec eliminator if you run 5s run a bec pack and yes 2000-3000 mah is good for run time if you need space get a extension for your bec pack. Personly helps me balance my 3s2p and my 2s2p lipos. good luck
                        • BIGDG357
                          • 243
                          just out of curiosity why would you not use the castle creations bec, maybe you can clear this up for me and Eggy.I am running this on 2 2s packs and it works great
                          • Christaphason
                            • Jun 2009
                            • 104
                            Why not? I'm wondering why you wouldn't want to save weight and not have to worry about charging another battery pack, also what if your pack is low and you start losing control of your boat, an external BEC will eliminate those problems.
                            Just my Opinion
                            • mtk
                              • Jun 2009
                              • 58
                              I am sorry if I am wrong but the bec eliminator I thought just changed the voltage and it won't have to do that if it is allready getting 6v I think that the bec goes up in flames because of the draw and all of the power and the extra power kills it. so if it works for you that great
