My Blackjack 26 Build
  • Christaphason
    • Jun 2009
    • 104
    I recently signed up to OSE but been viewing for months so, I Just thought i would share my blackjack with everyone.
    As of right now I am running the stock motor with an Etti 150amp esc.
    Fuller's Hardware.
    2.4ghz Futaba Fasst
    I have a couple questions I drilled a new hole to angle my turn fins, how does this compare to completely taking them off. I do not race the boat, its mainly just for playing around.
    One more thing, I ran Octura x642 and got 35.6mph with 7 cell nimh, but have any of you guys tried Prather 220.
    Also i just got my 7.4 volt lipo's in that ill be running with bullet connectors so hopefully i can pull more speed out of her
    sorry about the picture i had to resize in MS paint......
  • mtk
    • Jun 2009
    • 58
    if your looking for speed I would go with a lipo and a 5s and it will scream I was able to modify my stock turn fins to work and it works also if ur esc can take it use 6s and get a ammo 2300. I hit 47.3 stock apart from a grimracer 40-53 and a 5s
    • motohead417
      • Nov 2008
      • 91
      Hey sick hatch cover. Where did you get it?
      • Christaphason
        • Jun 2009
        • 104
        I got the hatch from Kintcracing.com
        Today i ran my BJ26 on my 7.4v 25c 5000mah lipos.
        My fastest run way 38.5 mph.
        Should i be running faster with my setup or is it time step up to a new motor
        Im running an Etti 150 amp
        I also Angled my turn fins in.
        5.5mm Bullet connectors on everything
        Fullers Hardware
        2s 5000mah 25c lipos
        Octura x642 and Prather 220
        My best run was using the Prather 220 prop
        Last edited by Christaphason; 06-28-2009, 08:58 PM. Reason: added that i have bullet connectors on everything
        • domwilson
          Moderator
          • 4405
          Do you have pics of the setup? Like the business end and the battery placement?
          Government Moto:
          • Christaphason
            • Jun 2009
            • 104
            Ahh i do not at the moment but i will get some next time i run
            I had my batteries about 3 inches from the transom.
            I played with Strut angle a bit and was able to pull out that .5mph
            Maybe it will just need more fine tuning
            Ill try to get pics sometime this coming week
            • domwilson
              Moderator
              • 4405
              How is the strut height?
              Government Moto:
              • Christaphason
                • Jun 2009
                • 104
                The last time i tweaked it, i had it pretty mush even with the angle of the stuffing tube. This is actually pretty straight with almost no angle at all.
                • domwilson
                  Moderator
                  • 4405
                  Try adjusting the strut height, not angle, up in 1/8" increments. See if that helps with the speed.
                  Government Moto:
                  • Christaphason
                    • Jun 2009
                    • 104
                    Thanks ill try that out this week, and ill let you know how it works out.
                    • domwilson
                      Moderator
                      • 4405
                      You'd be surprised at the difference a little strut adjustment can do. One of my cats went from high 20's to a low 40's just by playing with the adjustments.
                      Government Moto:
                      • Christaphason
                        • Jun 2009
                        • 104
                        Yeah i was starting to adjust today, but rain prevailed and i decided to pack up
                        • animigan
                          • Jun 2009
                          • 71
                          Just to clarify, that hatch comes from kintECracing...
                          • Christaphason
                            • Jun 2009
                            • 104
                            So i got a Feigao 8xl installed on my BJ26. The boat was significantly faster and had a lot more power.
                            Well i thought id test this power out and made a fast pass by, and long story short this boat doesn't like doing 10 flips at over 40mph
                            So im thinking about pulling all the wood out of the boat and making new rails out of carbon fiber.
                            • domwilson
                              Moderator
                              • 4405
                              Harsh...Looks like the epoxy let loose.
                              Government Moto:
