how do u adjust the turn fins and how much do i have to move it. any pics???
turn fin adjustment
Many posts on this but it sounds like raising the fins by using the lower hole on the fin and screwing it to the top hole on the boat, follow the angle of the outside hull and drill another one for the top and plug the bottom one. I just bent mine for the angle. I understand they need to be raised but I will try this first. The stock position is REALLY bad for cornering and you can see it when it comes at you, It leans to the outside. -
Has anyone tried these boats WITHOUT the turn fins installed? Cats usually don't need them... Though I know the sponson angles on these ones are relatively flat, so maybe it does...Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
I have,,,brings a whole new meaning to the term "squirrley". I put them back on after only one run without them.Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
This may be a simplification of what is actually needed, but if I keep the stock turning fin position in terms of drill holes, can I simply:
1) bend them to match the edge of the hull
2) shorten them instead of raising their position where they attach to the hull?
For those of you who have been slowly trimming the fins down, what tools have you been using? Any good recommendations of how much was needed to trim? As I surgeon, I know how much easier it is to take material away then it is to add it back on if you've gone too far...
Tweaking this boat would be so much easier if I owned a full set of tools and had a hobby shop in my condo...Comment
hardware
it is a fuller's hardware set up for a cat and you use the top two holes but have to drill two lower holes I then used flexible epoxy on the in side to seal it up. I also used very thin servo tape between the strut and the boat and did the same with the trim tabs. The epoxy is also to add strength here are a couple of pics.[IMG]
[/IMG][IMG]
[/IMG]
fins
They are about 1 1/4' long from out side corner to bottom. If I remember right I shortened them by 1/2', which is the distance between the two mounting bolts. instead of raiseing them to the top hole which is 1/2" I cut and bent them. You will need a vise.Comment
Tools are no problem, have a workshop in the garage with all the needed tools and plenty more.
Already sharpend mine, sharp as a knife and cuts a paper like a hot knife through butter.
There is plenty of mph lost by the turnfins, i got these results with my stock BJ26 runing 2S 20C Lipo's (except from the battery trays that has been removed)
Before Sharpening 54.9 Km/h - 34.3Mph (Stable @ Top speed)
After Sharpening 57.9 Km/h - 36.1Mph (Stable @ Top speed)
Removed Fins 60.3 Km/h - 37.7Mph (A bit shaky @ Top speed, uncontrollable in corners)
@ Krusty: Is there a big improvement in the handling? And did you gain or loose some speed on the top b doing this mods?Comment
Over stock I found a huge difference I can now make high speed corners, stock it would flip. Thanks for posting the speed diferences it sounds like I sould leave my fins on I was going to remove them to ensure I broke 50 mph but it does not seam worth it from what you said.
When I did these mods I did not have my gps yet so to be honest with you I am not sure. with my stock esc and motor on a x - 442 she ran 39.7 mph two day's ago and my best is 44 mph on the stock set up.Comment
[/IMG][IMG]
[/IMG]
