collet nut?
  • macz
    • Jan 2009
    • 118
    collet nut?
    ok I got the nut unscrew'd how do u get it off the friggin shaft? Why cant s**t be easy...
  • bigpapa
    • Apr 2009
    • 2330
    take the motor loose and slide the shaft out (:
    • bigpapa
      • Apr 2009
      • 2330
      or pull the shaft out from the back sometimes it's kinda hard to get out the first time
      • bigpapa
        • Apr 2009
        • 2330
        make sure nut is all the way loose
        • macz
          • Jan 2009
          • 118
          the nut is off the motor and on the shaft....i cant get it off...do i just yank and yank or twist it?
          • bigpapa
            • Apr 2009
            • 2330
            try twisting and pulling the collet must be really locked good
            • macz
              • Jan 2009
              • 118
              f-ing thing pulled the motor im about to cut it!!!! how is it lock on there?
              • bigpapa
                • Apr 2009
                • 2330
                collet to motor with a set screw the collet nut just pinches down on cable
                • bigpapa
                  • Apr 2009
                  • 2330
                  just be careful not to pull the bearing out of the front of the motor
                  • macz
                    • Jan 2009
                    • 118
                    well after twisting got it off but what grabs the shaft...it broke into a couple pieces...
                    • macz
                      • Jan 2009
                      • 118
                      whatever pinches down on the shaft broke....
                      • bigpapa
                        • Apr 2009
                        • 2330
                        need to buy a upgrade collet form the store here, they all break after a while real brittle
                        grade 8 hardned
                        strong but brittle no flex or stretch to it
                        good luck lube the shaft while it is out
                        • macz
                          • Jan 2009
                          • 118
                          is there a part number for that?
                          • bigpapa
                            • Apr 2009
                            • 2330
                            the collet fingers are known for breaking
                            • macz
                              • Jan 2009
                              • 118
                              can you link it?
