antenna hole?
  • macz
    • Jan 2009
    • 118
    antenna hole?
    What are you guys using to seal it..just tape or something else?
  • domwilson
    Moderator
    • 4405
    Hello,
    Some use tape. Others fiberglass theirs. I found a grommet that fit perfectly and seals fine while leaving my antenna in the original position.
    Government Moto:
    • MAXAMUS
      • May 2008
      • 200
      depends if your gonna use it Ive sealed mine by using a small bit of plastic you can use an old bank or credit card cut it larger than the hole and epoxy both sides to ensure a water tight fit ........
      Maxamus
      • bigpapa
        • Apr 2009
        • 2330
        i run a 2.4 ghz, spectrun d3xr, antenna is under hatch plugged hole stay's real dry underneath
        • HappyOne
          • Jul 2008
          • 179
          I mounted an antenna tube into a push rod seal and glued that into the hole to seal it all up.
          Grand River Marine Modellers, el Presidente
          IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
          • macz
            • Jan 2009
            • 118
            Where did you get the push rod seal? I the rubber piece from?
            • macz
              • Jan 2009
              • 118
              Will this work? http://www3.towerhobbies.com/cgi-bin...?&I=LXMNK4&P=M
              • macz
                • Jan 2009
                • 118
                or will this fit the hole? http://www3.towerhobbies.com/cgi-bin...?&I=LXMNK6&P=M
                or this http://www3.towerhobbies.com/cgi-bin...?&I=LXD589&P=M
                • HappyOne
                  • Jul 2008
                  • 179
                  I used the Dubro ones. That's what I found at my LHS.
