lipo C rating
  • MAXAMUS
    • May 2008
    • 200
    lipo C rating
    hi
    what do you think about C ratings on lipo's ?
    i ask because i am looking to get some 3cell lipos to run in my BJ and have seen some at 4000 mah 15c
    or some at 4000 mah 30-40c ????
    Maxamus
  • Blackjack-sven
    • Feb 2009
    • 371
    The "C Rating" is the batteries current rating. The higher the current rating the more the motor can show it's true potential. If the C rating is too low and the torque demand too high, it will seem like the boat is stuttering. This stuttering is very common to see on rc cars with poor quality batteries. When you punch the throttle the motor will demand a certain amount of current from the battery. If this demand is not met it will seem to stop and start very quickly.
    Long story short the better the C rating and quality of battery, the better your performance will be.
    On my BJ 26 I now use 4900 Mah 25c 2s Trak Power batteries but this is how my boat runs on a completely stock setup without ANY mods using 4600 Mah Intellect NI-MH batteries.
    This on the other hand is what the boat can do with my Trak Power batteries.
    HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
    • bwells
      • Jan 2009
      • 842
      In you post you said you use 2s but in the video it says 11.1 which is 22 volts which is a little scary for me as I don't want to burn anything up. It seems that 2 2s in series is about my speed as that is 14.8. the 2s2p increases the mah but not the volts, correct? for instance, 2 2s2p in series would get you 14.8 but double the mah, add more weight but what about the c rating, can you go 20 and be safe? Thank you, Brian
      • Blackjack-sven
        • Feb 2009
        • 371
        Sorry the video must be wrong as the voltage was 14.8v. As for
        you will be safe even if you went to a 30c because the motor will only pull the current it requires. Your controller is what decides weather or not you keep running, but if you keep the stock motor and esc then you will be fine. Just make sure you don't go to a too aggressive prop as that will increase the load on your controller and motor potentially damaging something. Stick with the stock prop, Octura x642 or any other prop in similarity to a 40x52/2.
        • MAXAMUS
          • May 2008
          • 200
          hmmmm
          look at these http://cgi.ebay.com/EC-POWER-10000mA...742.m153.l1262
          sure would get long run times here
          Maxamus
          • bwells
            • Jan 2009
            • 842
            but if you run 2 you would have 22.2 volts which I assume would be over the limit of the electronics on the bj26 plus they are from hong kong and I haven't heard anything about hong kong batteries. 2 7.4 4000mah 20c 30c would make me happy if I could get them for under 100 a pair
            • MAXAMUS
              • May 2008
              • 200
              but if you run 2 you would have 22.2 volts which I assume would be over the limit of the electronics on the bj26 plus they are from hong kong and I haven't heard anything about hong kong batteries. 2 7.4 4000 mah 20c 30c would make me happy if I could get them for under 100 a pair
              my 20c 6600 mah lipo's are from hong kong and are fine most lipos originate from eastern countries and are just re branded but remember you will need to check what voltage your set up can handle and run the bats in series or parallel as required
              series doubles the volts and the mah stays the same
              IE 2x 7.4v 4000mah = in series 14.8v 4000mah
              parallel doubles the mah and the volts stay the same
              IE 2x 7.4v 4000mah = in parallel 14.8v 8000mah
              Maxamus
              • Blackjack-sven
                • Feb 2009
                • 371
                Originally posted by MAXAMUS
                hmmmm
                If your going to go with something of this caliber then why not use the max amps 12,000mah lipo 2s3p? I know that maxamps batteries are of very high quality and you'll get the longest run times out there.
                LiPo batteries and Lithium Ion batteries for UAV, UAS, VTOL and robotics. Assembled in the USA.
                If you want the best bang for your buck from maxamps, use this battery. But try to find one on e-bay if you don't have the cash for a new one.
                • kookie_guy
                  • Jun 2008
                  • 897
                  another quick note is that you can destroy your batteries if your motor is trying to pull more current than your batteries can provide. They will get very hot, and pretty quick. With lipos, that's not something you wanna do.
                  I had this issue with my e-maxx when I swapped out to 700HO motors. My cheap NIMH packs just could not supply the juice, and they went for a poop.
                  In short, get the highest C rating you can afford. If you have no plans of upgrading your BJ any time soon, or running the packs in a high draw application, then a pack that can put down close to 100 amps is a VERY safe bet.
                  Personally, I will be running 4900mah, 2s rhinos in mine. They are rated 20C/30C burst, so 90 amps is plenty.
                  A good ref point is the rating of the ESC. If for example the ESC can only put out 60 amps before it goes for a crap, then you know the motor will not pull that (until you mod or load it obviously). So a 90 amp battery is again, very conservative.
                  • bwells
                    • Jan 2009
                    • 842
                    maxamus: 2 7.4 4000 mah in parallel = 7.4 volts 8000 mah but the stock wiring for the bj26 is in series. It would be easy to change to parallel but I'm running 2 8.4 4500 nimh in series now and I like the 2 pack thing for weight distribution. I guess 2 11.1 volt lipos in parallel would double the mah, never crossed my mind, I have to think about that idea but then your only running 11.1 volts whereas with my 8.4 nimh in series I'm ramming in a whoopping 16.8 volts, yeah, as 2 7.4 volt lips in series would give me 14.8 which is good I guess cause they are lipos.
                    • Blackjack-sven
                      • Feb 2009
                      • 371
                      These are the specs of the stock Blackjack 26's ESC.
                      Specs
                      * Forward:Yes
                      * Brake:Yes
                      * Continuous Maximum Current:45A
                      * Input Voltage:Minimum 10V, Maximum 21V
                      * Momentary Peak Current:55A
                      * BEC Voltage:5.8V
                      • bwells
                        • Jan 2009
                        • 842
                        blackjack-sven:
                        45amp continuos and 55 max thanks, now if I can find " the rule of thumb" formula someone posted something like volts times mah divided by 1000 equals max amp or c rating, I forgot but it for picking lipos, Thanks again
                        • kookie_guy
                          • Jun 2008
                          • 897
                          blackjack-sven:
                          you sure that's not for charging lipos? because with the above it's quite simple. If the esc peaks at 45 amps/55 amps momentary, then as long as your battery can provide 55 amps, you are fine. The most the ESC will provide is 55 before melting.
                          As a safety buffer, I would get packs that can spit out 50% more current, simply to make sure they have a nice long life. So, 55amps + 50% = 82.5amps.
                          Maybe the formula you are talking about is figuring out how many amps your lipo will sustain.
                          For example, 4000mah pack rated at 20c/30c burst
                          4000mah x 20c / 1000 = 80 amps continuous
                          4000mah x 30c / 1000 = 120 amps burst
                          • Blackjack-sven
                            • Feb 2009
                            • 371
                            I got this info off of the horizon hobby web site here.
                            • Chuck E Cheese
                              • May 2008
                              • 1684
                              do any of you know about running lipo's in parallel and series? i have plenty of rhino 4900 20c. i am looking to run a 8xl with 150 etti. i was thinking if i ran 4 packs, 2 in parallel then in series i would come up with 9800 mah at 14.4 volts. is this a problem to run them that way or is it the same to series them and then go parallel as it would be running 2 9800 mah 4 cell packs. i dont care about the run time, i'm looking for the batteries to put out more amps.
                              thanks
                              see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
