Teflon liner trick
  • 6S HYDRO
    • 1320
    Teflon liner trick
    HEY FOR ALL OF YOU WHO HAVE TROUBLES FITTING A NEW TEFLON LINER IN YOUR BLACKJACK'S STOCK STUFFING TUBE OR ANY BOATS STUFFING TUBE AT THAT. I WAS AT RAY FULLERS HOUSE/SHOP YESTERDAY, AND PERSENTED HIM MY PROBLEM, WHICH MANY SEEM TO HAVE (SEEING ALOT OF POSTS ABOUT HAVING TO SAND THE TEFLON OR USE CARBON RODS TO GET IT THRU) HEY ASSURED IT WOULDNT FIT UP THE TUBE, THEN HE WALKED OVER TO HIS VISE- CLAMPED ONE END IN IT AND THE OTHER IN A PAIR OF PLIERS AND SIMPLY STRETCHED THE TEFLON ABOUT AN INCH, (YOU MUST HAVE SLIGHTLY MORE TEFLON THAN YOU NEED- CAUSE YOU THEN MUST CLIP OFF BOTH CRIMPED SIDES) AND VIOLA- HE SLID IT UP THE TUBE IN .5 SECONDS. ITS AN OLD TRICK ONLY THE 30+ YEARS FE VETS KNOW ABOUT. NOW AFTER A COUPLE OF HOURS THE TEFLON WILL COME BACK TO ITS NORMAL SIZE AND BE SECURED SNUG IN THE STUFFING TUBE.
  • H2OCamel
    FAST ELECTRIC EVERYTHING
    • Oct 2007
    • 484
    Nice tip Thanks!
    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
    • Steven Vaccaro
      • 8720
      Ray has been around the block a few times! He's a good guy to be able to hang around with.
      I picked up the same trick from another seasoned racer a few years back.
      • Jeff Wohlt
        • Jan 2008
        • 2716
        Just be sure your ID does not get too small from stretching it.
        www.rcraceboat.com
        [email protected]
        • TCR
          • May 2009
          • 139
          Best thing to do is freeze the liner, then stuff it right in
          Tom
          • JimClark
            • 5907
            What about keeping the Teflon liner in a tube that is the same diameter and the Teflon slides in easily? Do you clue it in?
            Jim Clark
            Billy Graham
            • sailr
              • Nov 2007
              • 6927
              How do you keep the teflon from spinning inside the tube. I've had that happen too.
              Mini Cat Racing USA
              www.minicatracingusa.com
              • Steven Vaccaro
                • 8720
                I've used a piece of fuel or water line tubing over lapping the teflon and brass to hold the teflon in place. In some cases where my stuffing tube was not as well bent as it could be, I've had to search for a larger piece of teflon, so to have a snug fit in the stuffing tube.
                • 6S HYDRO
                  • 1320
                  well in the case of the bj- you wont ever have to worry about it moving around in there cause it will be super snugged in after the teflon comes back to its orig. size.
                  • 6S HYDRO
                    • 1320
                    i think they used some type of metric size for the stuffing tube on bj's perhaps
                    • TCR
                      • May 2009
                      • 139
                      You got that right!!
                      Tom
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        Yep...you can be certain it was metric.
                        www.rcraceboat.com
                        [email protected]
