What prop for Ammo 2300, esc Hydra 120amp and 4s - 5s lipos?
Prop suggestions for upgraded blackjack
Maximus.
In my experience the X642 doesn't allow the Ammo to rev. You will need to detongue it. Or get an M642.
An X640 seems to give me slightly more speed & less current drain in a mono. Might do the same in a cat. Not sure on that.
A Grimracer 40 X 52/3 blade is also a good prop on the Ammo. Again that's in a mono, But I did try it on an 8XL in my 32" cat & it was pretty damn fast.
The Ammo needs to rev, it's not a high torque motor.
Don't try the X645 on the Ammo. It will burn.
Regards.
Paul.See the danger. THEN DO IT ANYWAY!!!
Maximus.
Regards.
Paul.
thanks for the info will definitely look into getting some of those props and see what the difference is still have the x645 and still unused well looks like its heading for eBay or the swap shop lol
thanksMaxamusComment
I am using the ammo 2300 in my Campbell shovel with a Prather 215 and GPS says 43.4 MPH (70 kph). It runs faster but the GPS added 147 grams and it ran a bit wet on the sponsons. A friend of mine has the BJ26 and used a Prather 220 and said it was the best it has ever run but he had a stock setup.IMPBA 20481S D-12Comment
pranther 215 is about the same as a x640, he would have got away with a 220 with a stock motor as it is a lower kv and 6 pole, a pranther 220 would kill a ammoComment
Maximus.
The X645 is a great prop for the stock motor. Keep it for that if you intend to use that motor in another boat.See the danger. THEN DO IT ANYWAY!!!
