boat running at 25% of its power
  • srod01
    • Apr 2008
    • 3
    Well I purchased the ESC programming card looking to make the switch to LIPO, but tried it out on the NIMH batteries just for a test. Well after I did this the boat will only run a 25% power. I recharged the batteries and tried to reprogram it again but no look. I do not know what the batteries are putting out but I am wondering if this could cause this problem. The boat was running fine before I made this ill advised decsion. If it aint broke dont fix it. Any help with this matter will be much appreciated it. I used what I belived were the stock settings:
    High timing
    NIMH batteries
    Low voltage cut off
    no brake
  • Ub Hauled
    • Aug 2007
    • 3031
    which ESC is it?
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      High timing
      NIMH batteries
      Low voltage cut off
      no brake
      What ESC and what programming card. The card sounds like it is set up incorrectly.
      Douggie
      • ApacheDude
        • Sep 2008
        • 83
        I would advise low timing when running NiMH. Also Low cutoff with NiMH.
        Boats:
        Proboat Apache 24
        Proboat Blackjack 26 Brushless
        • Apples1
          • Dec 2007
          • 406
          Has anyone had any Luck getting the brake to work on their ESC?
          returning to boats after a big break
          • srod01
            • Apr 2008
            • 3
            I am using the stock esc and I purchaed the programming card form OFE
            • kookie_guy
              • Jun 2008
              • 897
              switch to low timing. everything else seems ok
              • srod01
                • Apr 2008
                • 3
                so the state of the batteries would not affect the programming of the esc?
                  • 8012
                  If the settings are what you say they are, there is no reason for you to lose 75% of your power from programming changes. I'd look elsewhere: bad batteries, a bind in the driveline, bad solder joints, motor wire shorted, damaged ESC.....
                  • sn00p
                    • Jan 2009
                    • 72
                    have you set to linear ??? otherwise you will loose power
                    • kookie_guy
                      • Jun 2008
                      • 897
                      ya the batts could be the cause too. I had a set I tried running in my truck which was power hungry and damaged some cells. Even tho they took a full charge again, they would not discharge enough for the boat, and even tho I had the run time, the boat barely moved, about 25% just like you actually. Yet another reason I went lipo. LOL!
                      • Ub Hauled
                        • Aug 2007
                        • 3031
                        Usually boaters don't use breaks...
