lipo cutoff reliability
  • kookie_guy
    • Jun 2008
    • 897
    ok,
    so during the offseason I'm switching to lipos. Gonna be running 2S 4900mah (x2). If I program to lipo and high cutoff, is the ESC reliable? Or should I still run an external LVC?
    • 8012
    What ESC do you have? If it's the stock BJ26 ESC it should be fine set on "high cutoff" which is 3.0 volts per cell. I prefer a 3.2 to 3.3 volts per cell cutoff, but as long as you bring the cat in immediately you should be fine. The "low cutoff" option is 2.7 volts per cell, 'way too low IMO.
    • kookie_guy
      • Jun 2008
      • 897
      ya it's the stock one. If I get an external LVC, is the voltage cutoff point adjustable? If you run an external one, you can leave it at low cutoff correct?
        • 8012
        There are many external BECs - some are adjustable, some are automatic. I don't see why you would not set the ESC's BEC at low (2.7 volts) since an external BEC should be set higher and would "go off" sooner. If you run the stock BEC without an external BEC, set it on high.
        I am not saying that the factory BEC is not good, I know nothing about its reliability. I just prefer to use a higher cutoff voltage.
        • thrashmetal
          • Aug 2008
          • 82
          re lipo cutoff
          i have been using the programming card to set the lipo cutoff on my blackjack brushless and have never had a problem with my lipos being discharged below 3 volts per cell. the lipo cutoff has always kicked in after running my boat and ive been running 6s lipo in my blackjack ( stock motor and esc)
          hydro & marine step 4 mono neu 1527 1y 6s
          blackjack brushless 26 bone stock 6s 55.4 mph
          ballistic racing team
