Help...Which is the best prop for the BJ 26...
  • hex-dj
    • May 2008
    • 238
    I have an octura x 640 sharpened and balanced prop with an Ammo 2300 & Fullers hardware. I want to know which prop works best with my motor without it having to be detongued ,but sharpened and balanced only (x 642 or 645?), by the way how do you do the detonguing on a propeller?
  • Steven Vaccaro
    • 8720
    Once you start the with all the mods its hard for someone to tell you whats best. You will have to start testing on your own to get the absolute best prop.
    Steven Vaccaro
    • Meniscus
      Refuse the box exists!
      • Jul 2008
      • 3225
      Egneg? care to chime in?
      Hex, I figure that Egneg may have a good idea what you might try.
      Why not detongued?
      • Steven Vaccaro
        • 8720
        Any one that tells someone "online" that they know the "best" prop for someones boat is not doing that person justice in my opinion. They may be able to come close. But only with testing can someone pick the "best" prop. There are many, many factors to consider. One of which is the water. I have run in different parts of the country where my boats needed different props than the "best" ones I use on my pond. Not sure why.
        Steven Vaccaro
        • Avanti
          • Nov 2007
          • 1280
          factors that play a part could include
          elevation
          weather
          if there is salt in the water and how much
          spring water
          cedar water
          brackish water
          Like Steve said someone with a similar boat can get you close, but only you & your local pond can truly find the best.
          • hex-dj
            • May 2008
            • 238
            Okay. I will do the testings myself. I ll also use my new radar gun to measure speeds.Anyone knows someone with almost my same setup so far. I have Ammo,Original ESC, 42 x 55 Grim 2 blade prop, x640, x440,40x 52 /3blades,40 x 53 ...LiPO 4s ,Very very lightweight boat ,scuffed bottom with rudder slightly in to push the bow up a little. Steven,How do you perform the detonguing on a propeller?
            • hex-dj
              • May 2008
              • 238
              Thanks Avanti and thanks to Steven ....& Meniscus.
              • Jeff Wohlt
                • Jan 2008
                • 2716
                With higher KV motors like the 2300 you will want to work on pitch and not so much dia. That motor will need to spin or it will amp out and poof.
                640 would be a safe start and like always. Time it and check heat. Also your set up is critcal. Make sure your strut is a couple mm from the bottom of the sponson and move up a little from there. Smaller dia and you can go deeper with the strut if needed. I like my boats running lose so I tend to run the strut a little deeper.
                Detonging is just removing the tongue at the lower end of the hub but they need to be the same when you do it. You can make an impression with playdo and work from there. This allows the motor to unload a bit on the lower rpms but also lets it spin a bit more on the top end. The boat will not plan as fast but will jump out once it hits.
                www.rcraceboat.com
                [email protected]
                • hex-dj
                  • May 2008
                  • 238
                  Thanks Jeff. But how many millimeters will have to be removed or is it the whole tongue?
                  • Avanti
                    • Nov 2007
                    • 1280
                    maybe obrien will chime in he had a BJ for a while and messed with all kinds of different props with the ammo 2300
                    • egneg
                      • 4670
                      Good question as every boat is a bit different as there are so many variables involved. I would start with 2 maybe 3 mm and try that. Look at the M series for what a detongued prop looks like.
                      IMPBA 20481S D-12
                      • hex-dj
                        • May 2008
                        • 238
                        Thanks Egneg
                        • jlr3rd1
                          • 240
                          what size shaft is on the blackjack 26 brushless? 3/16 or 4 mm???
                          2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
