I have a few questions. I’m new to the Blackjack and are running 8000 Maxamp Lipo’s. Boat is all Stock. I set the programmer to
Battery Type: Lipo
Cutoff Voltage: High
Cutoff Type: Slow Down
Brake: Off
Timing: Low
Throttle Curve: Linear
I’ve only ran the boat 5 times so far. But one thing I have noticed is after driving the boat for about 10 to 15min, it’s a bit slower. Not quite as much punch as when I first started. I also tape the lid with the Hatch Tape at all 4 corners to keep the water out. I have also lubed the shaft after the first run. I have noticed on one run quite a bit of water in the hull, I would guess about a cup or so. I was wonder if this was weighing my boat down is the issue. But after emptying it, it didn’t seem to be much faster. It was better, but after reading some posts here. I was wondering if it was the timing I chose. Could the motor be running hot possibly? I never thought to check to see if the motor was hot. I always see water pumping out the side so I knew it was cooling. So I wanted to ask if that sounds like a hot motor or could it be something else.
Thanks Brad
Battery Type: Lipo
Brake: Off
Timing: Low
Thanks Brad
