Electric HHO Boat - Is it Electric?
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3222
    Alright, I know that a lot of us here have probably seen the HHO craze. If you haven't, look it up (distilled water + electric power + electrolyzer = byproduct Hydrogen off of negative lead and Oxygen off of positive lead).
    So here lies the question. If I was to pickup a BJ hull, insert some canisters for water, run off of batteries, and basically create jet fuel for the thrust...Is it technically an electric boat?
    I'm leaning towards the BJ hull due to the cat design and stability on the water. I know that there are going to be those out there that will suggest that another hull might be good, but remember that I will need A LOT of the internal space for the HHO generator.
    I'm thinking something along the size of 35mm film canisters to hold the water (probably 6 or 8 in total. Or I could use a square tupperware.
    I plan on being able to adjust the production (throttle) by using a variable capacitor (mechanical from way back when that at one time were used in old radios) and using a servo to move. I've got several sitting around from old ham radio stuff.
    Similar to this:
    Anyway, I wanted some input on the project and also, the collective determination whether or not this would be an electric boat.
  • Eodman
    • Sep 2007
    • 1253
    Say What?????
    Why not filter the water you are running in? Less weight NO?
    I admit I have no freakin clue!
    Not knowing how tall the interior of the Bj is ... perhaps a Mean machine would be a good choice also - it's 11 inches wide!
    We did it with a Bang!
    Cats Are Where It's At!
    • Meniscus
      • Jul 2008
      • 3222
      Yeah, it would be nice to use the water that is coming in, but that implies that the water is going out and I don't want to lose the production of the Hydrogen and Oxygen. Does that make sense?
      I'm not sure that I would need the extra width, unless you're giving up your hull! LOL
      • Ub Hauled
        • Aug 2007
        • 3031
        I think it would be technically an electric boat but probably not NAMBA/IMPBA approved due to the conversion... with that being said, two things:
        what are the power specs for that puppy and
        where can I get one!?
        • Darin Jordan
          • 8332
          I'm skeptical as to whether you'll be able to generate enough jet thrust to get the hull onto a plane and still have it be drivable.
          However, I'm intriqued by the technology you've been talking about...
          Perhaps if you could figure out a way to use the jet thrust to turn a turbine and spin a prop it might work better???
          Then again, they do have airboats... so perhaps it would work...
          Only one way to find out! Let us know how it works out!
          Darin E. Jordan - Renton, WA
          • Spot Me 2
            • Jul 2008
            • 769
            But I really have no idea.
            I do know that if you get it working???? , I want to see VIDS!!!!!!
            MMGMMarine
            RobertsonRacing
            • Meniscus
              • Jul 2008
              • 3222
              No power specs. The basic concept of creating a HHO generator is, you apply power + and - of two different conductors in close proximity. This breaks the H2O molecules into Hydrogen and Oxygen.
              This mechanical variable capacitor has two different sections. Each section has a set of metal fins. The set on the bottom is stationary and the other one (appears at an angle) rotates to be flush with the other at the bottom. So, along those lines, if a servo is placed on this cylinder, you could essentially create a throttle for the production of the Hydrogen and Oxygen. The more surface area in close proximity, the more production.
              I hope that was a good explanation and it made sense!
              Warning Kids, Don't Try This At Home! It could blowup with any ignition source!
              My recommendation? DO NOT STORE ANY OF THE GAS! Use only as on demand source.
              • Meniscus
                • Jul 2008
                • 3222
                As a side note, this article just came out related to chemical source instead of batteries. I'll leave that method to the MIT types!
                Scientists have found an inexpensive way to produce hydrogen from water, a discovery that could lead to a plentiful source of environmentally friendly fuel
                • Meniscus
                  • Jul 2008
                  • 3222
                  hmmmmmm.....turbine
                  Now to reduce the number of moving parts and chance of improper ignition...
                  I have some other ideas, but nothing completely thought through for drive systems.
                  Keep the suggestions coming!
                  • eboat
                    • Aug 2007
                    • 693
                    I have tried the splitting of the water into H and O
                    I used a car 12volt battery and stainlless steel plates (4 layers with spacers so they do not touch electricly) with everyother plate pos neg
                    I had it in a 2L pop bottle with baking soda in the water ( you need an electrolite in the water for it to work better) It worked
                    I hooked it up to our garden tractor ( put the hose from the pop bottle right into the carburator) and you could hear the motor speed up when you turned it on
                    I even turned the tractor gas off and it kept going for a short time but finally stopped ( if I had two set ups it might keep running)
                    Two observations I had
                    It takes alot of electric power to do this ( the battery was dead before too long)
                    When the gas was being formed it did not make alot of pressure
                    So if you were going to try this in a boat you will go alot farther using the power from the same battery to run an electric motor that spitting water
                    Unsure if you were thinking the gas would come out fast enough to push your boat ( it will not from what I have seen) or you were going to burn it in a nitro motor or turbine ( you still have to charge the battery)
                    Just my observations from a backyard mad scientist
                    • Ub Hauled
                      • Aug 2007
                      • 3031
                      I see... not quite there yet as far as RC goes... but
                      How do they do it?
                      • eboat
                        • Aug 2007
                        • 693
                        How do they do it?
                        Looks like in the fuel cell (from Honda)they said it combines H2 and O2 to get electricity
                        There must be a way to get electricity off this chemical reaction when it happens instead of heat ??? just a guess
                        • Meniscus
                          • Jul 2008
                          • 3222
                          Yeah, I've tried all types of materials, arrangements, etc. and I add baking soda as well as a little peroxide (for cleaning).
                          The issue related to battery drain is a direct result of the load that you are putting on it. For instance, if you use wire, you have more surface area for the equivalent amount of material , less resistance, etc. These small fins on the variable capacitor made of aluminum seem to have the best balance of corrosion, production, batt drain, etc. Of course, wire would be the way to go if you could keep separate, keep the current flowing through the wire (no coils touching), and density within the water. The problem with the wire is that it usually has to be replaced more often, you run the risk of the polarity touching due to vibration, and it is sooooooo time consuming feeding wire through a frame (speaking from experience). Plus I can do the servo for throttle with the variable capacitor. I know that someone out there is saying, this guy (me) doesn't get it, he should just.....
                          I've run off of various rc batteries and have had very little drain (10-12 mins or so to drop 20%)
                          So far as the thrust, I'm not counting on the pressure. In fact, I'd like to setup with a vacuum. But nonetheless, I plan on burning the HHO molecules.
                          I'll probably make sure that the hatch can blow off and like Spot said above, I'll definitely have the video camera running all the time!!!
                          • Meniscus
                            • Jul 2008
                            • 3222
                            Thinking...
                            If I go with a Turbine, why not let it be a generator at the same time and feed back to the electrolyzer?
                            hmmmmmm.....
                            • eboat
                              • Aug 2007
                              • 693
                              It will be interesting to see what you will come up with :)
