Wanting to upgrade the ESC and Motor to a Hydra 120 and a NEU motor, but not sure which NEU to buy. Any help would be greatly appreciated.
Upgrade ECS and NEU motor question..
Tags: None -
If you are going to put a neu motor in your boat you will need a hydra 240. how ever, that will pretty much be pointless since the boat won't be able to take the power. I would save your self alot of money and go with the hydra 120 and the ammo 2300 or one of the Feigao motors. -
Thanks alot. Which Feigao motor would you suggest.Comment
What would be a good race and corner motor and which would be a good straightaway motor to break 50? I am going to keep the stock motor/esc for reasons, but I want to push this boat to the limits and want to get some new boats also so I am getting these parts for this boat, but thinking ahead also. Thanks so much for your help. I know you have broken 50 and I want to join the club. I have done alot of looks work to her now its time for speed work. If I gain any knowledge from you I promise to share right back.Last edited by chisoxguy13; 06-03-2008, 11:45 PM.Comment
the ammo motor and a hydra 120 will get you over 50. I hit 51.7 I believe with trinity nimh 4200s. I will say, that you have to play with the prop to get it to run the best. I just continued working on the prop. I know there is probably even more there, but the trick is keeping it on the water. I blew that hull over so many times that it finally broke. I glassed it back together, but its a good bit heavier now. I have another hull but its a nitro hull that s heavier, and I may try to go for 60 with that one since it should handle more power.Comment
Thank you so much. Does the stock motor have the ability to break 50? I'm finding it hard to find props right now, but have a 642 being sent thank god. I got the all stock setup to 39 with a pair of venom 2S 7.4 5000MAH batteries. I am thinking about going with the Hydra 120 and Feiago L motor since I can get the cooling jacket for it. How eash it the HYDRA to program? Just got a pair of ThunderPower 2S 7.4 5000MAH. The wiring they use can't even let the full power of the batteries out though. The guy at my LHS said he is going to talk to the companies about that. The Antique Barn in Wilson, NC is a huge retailer for the area. The only problem is that there aren't any FE boaters around here. I have learned so much in a short period of time from these forums though and I appreciate everyone helping.Last edited by chisoxguy13; 06-05-2008, 10:28 AM.Comment
I went with the neu 1515 1y motor and the hydra 120. Using octura y535 prop and two 7.4 4000 li-pos with the tlr skatter system and the breakaway fins. I would not recommed trying to buy from twisted liqued racing, they are scam artist they make you pay for your order up front thru paypal and then they do not deliver. Aeromarine has a kit that is way better for a few dollars more, that is what i am getting for my other 3 blackjack 26's. Hope this helpsComment
I had an issue with them also and after talking to the owner at 2am on the phone my issue was resolved. They are a newer company and do have some demand issues it seems. Ok back to the subject. How are you pushing that motor with a 120?Comment
50 might be possible with the stock motor, with lipos and the right prop. Like I said, I think I was just shy of 45 the last time I tried the stock motor. Since that is a lower kv motor, you might get away with a bigger prop than the 642, or maybe adding some cup to the 642. As far as programming the hydra, I recommend buying the program cable and using your computer to do it if you can. It takes about 1 min to make any changes that you want.
Its funny that you say Wilson NC, I was born there and grew up just a couple hours away.Comment
have you actually run that setup? If so, how are you not burning up the ESC with that motor. I quess with that small of a prop, there must not be much load. What speeds are you seeing?Comment
Way small world. Ha Ha. Where'd ya grow up at?50 might be possible with the stock motor, with lipos and the right prop. Like I said, I think I was just shy of 45 the last time I tried the stock motor. Since that is a lower kv motor, you might get away with a bigger prop than the 642, or maybe adding some cup to the 642. As far as programming the hydra, I recommend buying the program cable and using your computer to do it if you can. It takes about 1 min to make any changes that you want.
