Well I'd try that the adapter first, The Black Jack uses one, it's shaft is 1/8th, I'm not sure if there's enough length on the ep1 shaft though to fit a 3/16th prop hub.
those look like 430's the problem with a vee hull is the chine walking..I've tried and given up...A cat has 2 hulls to displace the the prop walk better, but it looks cools though..I like to see it run, by looking at it's setup the batteries toooo far back.
Well guys I took my cat out at lunch for a quick test drive .... well everything got real warm - esc shutdown ...etc...
RCprince could you post a couple of close ups of your cooling solution? I think the motors aren't get enough water to cool them down!
I upgraded to Reedy Spec 19 quad mags & when I put the cooling coils on them they probably are not tight enough! I'd try the silicone cooling jackets that Steve sells if I can figure out the correct size! Any help ????
I'm using a BJ Motor http://www.offshoreelectrics.com/pro...rod=dh-prb3310
which looks like a himax 6 pole 3630-1500 which is 87% efficient and a CC Barracuda 125 cooling is not an Issue...i'm not sure if those 19's have enough torque to be efficient enough to push that hull, what size props are you using....
Well guys. I just got my order of 2 EP1's in today and I must say I'm impressed. They are way bigger than I thought they were. I can't wait to mount them on a hull. I decided to rebuild my Skunkworks with the 9xl and stuffing tube set up. So now I need a hull to put them on.
Any ideas/suggestions on a good hull?
If your gonna run the 9XL your gonna need to drill out the drive dogs...and you gotta re mesh those gears right or you'll be Steve's best order buddy.
