This is a copy and paste from another thread I posted in. It gives some general info on drive hardware.
Quote:
Originally Posted by lyndon915
I have been all through the handling issues thread. I have seen the fuller hardware and am just wondering what some of my other options are and what I am going to gain by running an inline rudder or an offset.
Inline hardware:
Will give you almost equal turning both right and left, I say almost because the torque from the motor and rotation of the prop are factors too. Will also lose a little speed because the rudder is in the path of the props thrust.
Offset hardware:
Will give you superior turning in one direction, the direction depends on which side the rudder is on. Should run faster because there is nothing in the path of the props thrust.
Other considerations:
The distance between the rear of the transom and the prop will affect the boats speed and stability and how easy it blows over backwards.
The farther back the prop the more stable and less likely the boat will blow over because the prop has more leverage to keep it from happening.
The closer to the transom the prop is the more speed you should be able to get because the boat will easily get more airborne, but might blow over easier.
If that doesn't help keep looking at the different threads in these forums they will help you make your decision.
http://forums.offshoreelectrics.com/...ead.php?t=3643
Inline hardware:
Offset hardware:
