Sounds perfect to me. You're not getting much cavitation at all.
Fixing the BJ26 Handling Issues
Dirty, yes you will need to fill the old holes and drill two new ones. I used epoxy to fill the old holes. Please read through the first few posts in this tread for more info on all the mods done to the boat.Comment
What kind of speeds should you expect out of the stock setup, boat was bouncing on top of the small waves, but it took a while to get on plane. I hit around 26.9 mph with 7 cell 4200 traxxas and a 3 blade prop, I am going to try the same setup witht the stock prop, I have lipos but one has a bad cell, I think.Last edited by roadrashracing; 04-02-2011, 05:14 PM.Comment
went back out, still not really smooth, a lot of jumping around, ran the stock prop. With stock prop it got on to plan a lot easier. The first pack I ran was a new set of seven cell. Got 27 mph even, then I put the lipos in 30.7 mph.Attached FilesComment
Stock motor, stock esc, I get almost 43mph out of mine. X642, detongued and tip cup. Lipo, 40C 5000mah 4SComment
Detongue is removing the area close to the hub that kinda swings forward and then back to the tip. Easiest way to explain it, look at a M445 and an X445. The "M" series props come detongued from the factory. Cupping is very slightly bending the tips back and or the traling edge of the blade. That kinda describes it, its a bit more involved and easy to mess up if your not careful.Comment
Had my boat out today, it went well until I took it to the other side of the pond and ran out of room, the front has a small crack along the seam, but I did not spilt it open, I'm sure it will get a few more war wounds before summers done.
http://www.youtube.com/user/112racin.../0/fejMrqO-fI8Comment
