blackjack brushlesss shaft and prop
  • Steven Vaccaro
    • 8724
    Does anyone have a picture or info on the shaft sizes of the bj26 bl?
    Also what prop comes stock? Does it come with a sleeve to fit the larger props.
    I would look at one, but I ran out of them and need to find out asap.
    Steven Vaccaro
  • SJFE
    • 4735
    Look up Doby Steven. I believe I sold him a complete setup not to long ago. I will look for my pics also.
    • domwilson
      Moderator
      • 4405
      I think it is a 1/8" shaft.
      Prop Size:1.6" X 2.5" COMPOSITE
      and it uses a sleeve to fit 3/16" props.
      Government Moto:
      • Steven Vaccaro
        • 8724
        Dom I'm trying to figure if the blackjack brushless comes with the sleeve and uses a 3/16" stock prop?
        Steven Vaccaro
        • obrien
          • Nov 2007
          • 1264
          my boat did not come with a sleeve. I had to make one.
          • domwilson
            Moderator
            • 4405
            Mine came with a brass sleeve and it is the 3/16" stock prop.
            Government Moto:
            • Apples1
              • Dec 2007
              • 406
              mine came with no sleeve, so if i get this it should be ok? i want to run the 642 http://www.offshoreelectrics.com/pro...?prod=ose-1035
              not sure about prop shaft sizes, it's not a 3/16 stock shaft as i have these in my EX (an upgrade) to run X447 props and these wont fit on my BJ26 BL
              Octura x447
              Diameter: 1.85"
              Total Pitch: 1.4x1.85=2.590"
              Shaft Size: 3/16"
              Will double check tonight.
              returning to boats after a big break
              • domwilson
                Moderator
                • 4405
                I double checked. It is a 1/8" shaft. The prop is a 3/16" prop with a brass sleeve. Same prop as the TC31
                Government Moto:
                • Steven Vaccaro
                  • 8724
                  Octura x447
                  Diameter: 1.85"
                  Shaft Size: 3/16"
                  Apples and Obrien can you guys check to see if the sleeve is stuck inside the stock prop. If it didn't have a sleeve the stock prop would be really loose on the shaft. Is this the case?
                  Steven Vaccaro
                  • RCprince
                    • Jul 2007
                    • 1637
                    Steve the stock prop came with a brass sleeve, the drive dog was on a 1/8 shaft with sleeves on the back and front of the steerable out drive...
                    • Apples1
                      • Dec 2007
                      • 406
                      sorry guys didnt get a chance to check last night, but the prop certainly isnt loose on the shaft.
                      cheers guys.
                      • gaboulware
                        • Jan 2008
                        • 16
                        There is a brass sleeve wedged into the stock prop reducing from 3/16" to 1/8"
                        • Steven Vaccaro
                          • 8724
                          thanks for all the help
                          Steven Vaccaro
                          • Apples1
                            • Dec 2007
                            • 406
                            that is true....however an aftermarket prop wont fit on the stock set up, the length of the shaft isnt long enough (or the prop os to big) and the little piece of steel that stops the prop from spinning is to small for my x447
