Just made my own water pickup for BJ
  • Joe007
    Joe
    • May 2008
    • 124
    I have had my fullers for some time now so I changed out the rudder to make it off set and took off my steering fins and filled in the last step on the BJ... Since I did not want to cut up my fullers stock rudder assembly I went to the LHS and bought a piece of aluminum tube 5/32" and sqeezed in my vise to make the pickup more oblonged to make less drag in the water... Here is acouple of pictures of what I did....P6223239_edited-1.jpgP6223237_edited-1.jpgP6223238_edited-1.JPGP6223236_edited-1.jpgP6223234_edited-1.jpg
    Joe
  • Stephavee
    I like cool things!
    • Jan 2011
    • 218
    How much did it help to fill your last step in? I've been thinking of doing this myself
    " Do you really need anouther boat "
    YEP!
    • Joe007
      Joe
      • May 2008
      • 124
      It made my boat handle so much better. To me it is a must upgrade on the blackjack. And if you do the upgrade take off the turn fins you will not need them anymore.
      Joe
      • Stephavee
        I like cool things!
        • Jan 2011
        • 218
        I see you let the ends run further than the transom. Im assuming this was done for a reason?
        YEP!
        • Joe007
          Joe
          • May 2008
          • 124
          I did that to see if it will help keep the nose down in quick throttles and to keep the boat my stable on fast runs.
          Joe
          • jkypta
            • Feb 2012
            • 30
            what did u use to fill it in? it looks like plastic and how did u attach it?
            why do R/Cs seem faster when they are running away with no control?
            • Joe007
              Joe
              • May 2008
              • 124
              You can get plastic the right thickness at your lhs. I used balsa wood that I had. I used an opoxy based
              Resin. I painted the balsa wood first and then used the two part opoxy to attach to fill in the step.
