trim tabs
  • justinspotanske
    • 16
    trim tabs
    what someones opinion . I have a bj26 bl . I have the stock steering tabs that go straight down . Do you think the tabs the go level will help with the steering . My thought was that they would cause it would prevent the boat from tipping to one side in a turn . Let me know your thoughts or if you have done it and did it help . also what type you went with
    thanks
  • Diesel6401
    Memento Vivere
    • 4203
    There a thread here on the BJ handling issues you should really look into. As far as your question no I wouldn't suggest using trim tabs on a cat and actually I would take the turn fins off as well. If you remove the battery trays and allow the batts to sit lower, that helps. Check out that thread it will help you.
    http://forums.offshoreelectrics.com/...ead.php?t=3044
    - Diesel's Youtube
    - Diesel's Fleet
    • fatboyelectric
      • Feb 2011
      • 84
