full throttle cut out
  • justinspotanske
    • 16
    My issue is that when I try to go over 2/3 throttle the boat dies . let sit for a sec and go again and once again it does it . Over and over I use venom 5000mah 7.2v batteries. I have also reprogrammed it to : low on the voltage cutt off , idle on the cut off type , brake off , timing low , and linear on the throttle curve . Am i doing a wrong setup ? anyhelp would be nice . thanks I should also say the boat is a proboat bj 26 brushless . stock esc and motor
  • dana
    Banned
    • Mar 2010
    • 3570
    Your batteries are junk. Try brand new ones. I went thru it with my elam
    • justinspotanske
      • 16
      These are new , used less them 3 times
      • dana
        Banned
        • Mar 2010
        • 3570
        Hmm... Well I still wouldn't trust them. Venoms aren't great, and brushless boats are extremely hard on Nimh batteries. Maybe I'm wrong but I went thru the same problem with my Elam. Would never let me get up to full throttle before it would cut out. Then I would wait a few seconds and try again and same thing.
        • dana
          Banned
          • Mar 2010
          • 3570
          You shouldn't have any voltage cutoff with Nimh packs
          • justinspotanske
            • 16
            so does that mean to put it high or low on the programming card
            • dana
              Banned
              • Mar 2010
              • 3570
              You can't turn it off? I guess low. It's been so long since I've used that stuff. Someone else will chime in... I hope
              • justinspotanske
                • 16
                I also use duratrx 5000mah . besides the original question , what batts do you recommend
                • dana
                  Banned
                  • Mar 2010
                  • 3570
                  If you use Nimh mode on you're program card it should disable the lvc automatically. Not sure tho. Have you run these packs successfully in that boat already?
                  • justinspotanske
                    • 16
                    neither of the 2
                    • dana
                      Banned
                      • Mar 2010
                      • 3570
                      So none of your packs work. You're system requires a high discharge pack. My guess is your packs can't handle the job
                      • justinspotanske
                        • 16
                        can u recommend any?
                        • dana
                          Banned
                          • Mar 2010
                          • 3570
                          Does your charger do lipos?
                          • justinspotanske
                            • 16
                            yes , but not intested in lipos
                            • dana
                              Banned
                              • Mar 2010
                              • 3570
                              Ok. The proboat packs will do the job... For a little while. But I promise you your boat will kill them after a little while and you'll need new packs. Nimh cells just can't stand up to the demands of brushless power in a boat.
