I'm open to any advice and suggestions on this...
This weekend while running full speed, the u-joint broke and bent the shaft so much that it broke off the part of the hull that the tube runs through. I'm familiar with fiberglass repair, so my plan is to clean up the break, epoxy it, and apply a thin sheet of fiberglass or carbon fiber over the area for strength.
The shaft was lost, and it's probably a good time to replace all the running gear anyway. I've done a bit of searching and find a lot of references to a company that is out of business, and also to Fuller's Catamaran parts. Are there any others I should consider? I'm not trying to build a race boat, this is for me and the kid to play around with. Reliability is the top goal, with on-water stability the second. Speed is the least important (this thing already flies with the 5S 4000mAh batteries we usually run). Cost is not a big deal, would just like it to work reliably when we want to play.
Some links to specific parts would be greatly appreciated. This is our first boat and I have no familiarity with boat RC stuff. We previously have only had helis, planes, and cars.
