I just put in a .150 kit from octura for $8.50...sweet
I am assuming that with a new flex cable, the cable has to be cut to length. Is there anything special I need to know about doing that, or am I wrong?
I want to put a strut and rudder stet up on mine with a full cable so I can get rid of the universal setup.
I use a separating disk fitted to a dremel tool. Smooth the edges gently with fine sand paper. Melt solder circumferentially onto the terminal 1/2" where it enters the coupler. You may have to file off the extra solder to ensure a passive cable fit into the coupler.
If you're deviating from the stock Hardware, Get rid of the Turn fins. I recommend the Speedmaster 0.21 Round Bottom Strut and Hydro Rudder with 1.5" length. I have this set up in a Mean Machine and the boat runs bone dry.
I would'nt ditch the fins....I wish I would have left them on. The boat turns like crap without them. IMO from seeing other people vid's and seeing my own run. I say leave them on! This is not a mean machine....Although I wish it was...
