The Drain plug at the back does allow the boat to take on water in mine.
Sat it in the bathtub for 60 seconds and had water on the right side.
Going to use something to seal that up better.
You really have to cake the Marine grease through the Shaft passage to stop water from coming in also.
Run #3 with a prop adjustment and the boat is more stable around the corners and seems to sit up a bit quicker
I pack it in every run, bone dry inside. it helps when siting at the starting line, holds back the water for awhile.
