Castle 120 vs 240 esc
  • G-UNIT
    • 949
    I'm looking at buying a new esc soon and I'm trying to figure out whats the
    difference between the two, both can handle 6s or can the 240 handle more then that? and can you run both with the built in bec or do you need to run a battery pack?
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 409
    They both can handle 6s & they both have to have the bec disconected running 6s , yes you have to run a battery pack or you can buy the Castle bec unit off OSE but i think they are out of stock
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    • G-UNIT
      • 949
      Theres a big difference in price so whats the benefit of the 240 ?
      nad can the 240 handle higher voltage then a 6s
      • scoota
        FE DOWN UNDER
        • Dec 2008
        • 409
        What set up are you running ? I would not buy a castle 120 save your $$$ i have smoked 3 of them & will never touch one again !!!!!
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 409
          NO the 240 can only handle 6s the difference is the AMP rating ONLY
          • scoota
            FE DOWN UNDER
            • Dec 2008
            • 409
            I would look at a swordfish 120 AMP or a seaking at half the price of castle they both handle 6s or the swordfish 240 amp esc can handle 12s
            • G-UNIT
              • 949
              right now I'm running stock motor and esc on a bj 26 with speedmaster hardware and 4s 5000mah 40-50c lipos
              • scoota
                FE DOWN UNDER
                • Dec 2008
                • 409
                A 120 amp should do you with a stock set up the BJ esc is only 45 AMP .. Running a 120 amp ESC will give you some room to run some bigger props with out smoking the ESC , The bigger you go in prop size means you draw more AMPs....
                • G-UNIT
                  • 949
                  GOT IT ! Thank you very much.
                  • scoota
                    FE DOWN UNDER
                    • Dec 2008
                    • 409
                    Glad to help .....
                    Jason
                    • G-UNIT
                      • 949
                      can you imagine a BJ on 10s, just put wings on it an turn it into a glider or watch it desinagrate like an astoriod hitting the atomosphere.
