Brushless motor specs?Size?
  • CatMan
    • Jun 2010
    • 96
    Hello again
    I am having trouble figuring out what these numbers mean for a brushless motor 36-60-15L when they are listed 1600Kv I understand (Barely) but when they have the 3 sets of numbers I am lost. could someone please explain
  • crabstick
    • Jul 2008
    • 954
    36 is the diameter, 60 is the length of can ( not including shaft ) im pretty sure in this case, 15 is the number of winds which dictates the KV of the motor.
    HTH
    Matt.
    FE, Nitro and Gas racing in Auckland
    www.rcboats.co.nz
    • CatMan
      • Jun 2010
      • 96
      Thanks for the info! How would this motor compare to the stock one? is it twice as long? is stock motor 36 - 30- 15 ? would that mean 36-60-15 more powerful?
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1598
        Not sure why they call the factory motor a 36-30 but it's not 30mm long. It is just over 50mm can length. A general rule of thumb is a motor in the same diameter but longer will yeild more power.
        FE BOATING: Less like a hobby and more like an addiction!
        • Stephavee
          I like cool things!
          • Jan 2011
          • 218
          on the proboat website it says the stock motor is 74mm long? are they high?
          " Do you really need anouther boat "
          YEP!
          • Make-a-Wake
            FE Rules!
            • 5554
            Thats most likely total length including the shaft. If you want more power look into a 3660-3665
            • Stephavee
              I like cool things!
              • Jan 2011
              • 218
              I got a leopard 3674 on the way!
              YEP!
