New to the water. few questions
  • Rossco
    • Jun 2010
    • 15
    Hey all. I bought this boat cuz some of my hobby buddies are going to a lake this weekend and i did not want to go empty handed. I come from Rc cars with 2 slashes and 2 hpi bajas 5bs.
    my first question is will this boat handle 30c twin 3s lipos or is 2s the way to go. i am not going to go to crazy with this thing in terms of mods so stright lines a few turns is all.
    second is i will be doing the battery tray mod asap but how do i hold the batteries down after? velcro? is it really worth all the trouble to a very easy going user?
    thanks! also what runtimes would i get at stock setup with 2s 5000mah batts.
  • Rossco
    • Jun 2010
    • 15
    no help? damn... lol
    • crabstick
      • Jul 2008
      • 954
      Edit - Sorry didnt see it in the Blackjack section
      Stick with two 2s batts in series. Yes, Stick on velcro should be fine, definately fasten them down as they can shift moving the COG of the boat, runtime will depend on prop, setup and driving style, 4-5 mins or so is what id expect
      Matt.
      FE, Nitro and Gas racing in Auckland
      www.rcboats.co.nz
      • Rossco
        • Jun 2010
        • 15
        Is there a sweet spot for the Lipos?
        • crabstick
          • Jul 2008
          • 954
          I would probably move them back until the boat gets all flighty, then move them forward again a wee bit.. you will get the best performance right on that edge
          Matt.
          www.rcboats.co.nz
          • Rossco
            • Jun 2010
            • 15
            perfect! thanks.
            • Meniscus
              Refuse the box exists!
              • Jul 2008
              • 3222
              What prop are you considering running? If you're sticking with stock and the wind isn't bad, I'd personally pull the trays and put the lipos a 1/4" back. If she runs real wet, move her back some more.
              Definitely do yourself a favor and add flotation to the hatch.
              • Rossco
                • Jun 2010
                • 15
                I am doing the flotation on the roof as we speak. 2 big pieces of foam. Stock prop for now.
                • tmaxx1970
                  • May 2010
                  • 7
                  I'm running 2x2s 5000 and if you drive it respectivly I can run up to 20 min before esc shuts down and it is shutting down at about 3.25 per cell so that's pretty good.
                  • Skullcracken
                    • May 2010
                    • 617
                    Whahh??? 4-5 minute runtime. I have a blackjack 26, with two 7.4 volt 40c 5000's, and it runs a good 15 minutes.
                    • G-UNIT
                      • 949
                      Up to about 12-15 min full out wot, slowing down around 13 min.
                      • Rossco
                        • Jun 2010
                        • 15
                        i am getting around that much also. dunno why someone told me 4-5.. also is it possible to do 1 2s and 1 3s
                        • G-UNIT
                          • 949
                          Yes it is and that would make it 5s, I want to try that also, just keep your mah and c rating the same.
                          • Rossco
                            • Jun 2010
                            • 15
                            damn now I gotta find a 60c 5000mah 3s hahah
                            • Meniscus
                              • Jul 2008
                              • 3222
                              It's also a good idea to match the same manufacturer with same cells and similar cycles on the lipos. Otherwise you may find you'll drain one of the cells lower than what is safe before the ESC hits the LVC = Low Voltage Cutoff. If you don't, you risk losing one of the batteries, shortening the life of other components, and possibly destroying anything close to that battery that comes in contact with the flames or smoke. => Just trying to ensure you don't have a bad day at the pond.
