Blackjack Prop adapter
  • Jeff Wohlt
    • Jan 2008
    • 2716
    Someone here asked me to make some of these so they could use the stock 3mm prop shaft on their BJ for 3/16" hub props. I do know the M440 on the stock set up is excellent running 4S.
    Here it is. Set screw from Drivedog locks on to the orginal shaft...I would grind a slight flat spot. Now you can run 3/16" hub props on 3mm shafts.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
  • domwilson
    Moderator
    • 4405
    What would you estimate the final cost to be?
    Government Moto:
    • Darin Jordan
      • 8332
      Jeff,
      While you are tinkering, you may want to add a 5mm to 1/4" prop adapter to your lineup as well... The HyperSport 48, for example, has a 5mm stub shaft... I've had to make my own adapters using 1/4" OD brass tubing, then carefully drilling it out with a very close to a .1968 drill bit... (13/64ths, I think it was... .203125")...
      Just sleeves, of course... not as fancy as what you've done here...
      Darin E. Jordan - Renton, WA
      • Jeff Wohlt
        • Jan 2008
        • 2716
        Dom...not sure but with shaft only then I would estimate $6. They are SS.
        Darin...do you want to take that shaft down to 3/16" or will that boat carry 1/4" props? I can do either.
        www.rcraceboat.com
        • Darin Jordan
          • 8332
          BIG Gas Mono... needs to be upped to 1/4"...
          • Jeff Wohlt
            • Jan 2008
            • 2716
            Okay, Darin. All I need is the length from the strut to the end of the stub shaft. Not sure what nut that takes either but will check.
            www.rcraceboat.com
