What octura strut & rudder
  • G-UNIT
    • 949
    I am on a budget and would like some info on octura strut and rudder hardware you might suggest, how long is the rudder on most bj 26 set ups my lhs has quite a bit of octura stuff, maybe i can get a mark down
    since they are not to great on boat items
  • Steven Vaccaro
    • 8724
    You could try a oc6str-130 but the rudder is a bit short for the blackjack.
    This is the ticket for the Blackjack
    http://www.offshoreelectrics.com/pro...prod=ose-80085
    • Jesse J
      Former scale FE racer
      • Aug 2008
      • 7198
      I've got that on my 27" cat and it works great! Plus if your motor coupler decides to let loose, you have a built in keeper!
      "Look good doin' it"
      See the fleet
      • Doby
        KANADA RULES!
        • 7277
        I have that on my BJ and wow, what a difference in the way it corners!!!! Great hardware!
        Grand River Marine Modellers
        • koenvd
          • 1
          the *!***!***!***!**ing thing is, in belgium we have no shops whit that kind of stuff...
          new member (from belgium) with BJ26 !
          grtz Koen
          • Steven Vaccaro
            • 8724
            grtz Koen
            Its the same in the USA.
            • jaybird
              • Jun 2008
              • 12
              Does the stock bj26 push rod fit on that harware steven or do you have to get a longer one?
              • animigan
                • Jun 2009
                • 71
                NO, the stock push rod doesn't fit - you'll need more length and you'll have to adjust for the height difference as well if you keep the stock servo position.
                Andre
                • jaybird
                  • Jun 2008
                  • 12
                  So can i get a longer push rod from o.s.e cause i cant find them on there web page. Thanks
                  • wakeboardfusion
                    • 462
                    your LHS should have them for airplanes
                    • jaybird
                      • Jun 2008
                      • 12
                      I live in bermuda and we dont have any hobby shops so i gotta order online and dont really know wat push rod will work i would like to order everything one time if i can.
                      • wakeboardfusion
                        • 462
                        try tower hobbies in the plane section.
                        • MAXAMUS
                          • May 2008
                          • 200
                          will this fit directly onto the bj26 at the moment i have fullers os cat hardware fitted but the rudder has gone slack on the strut have drilled out and repaired but looking at a new set
                          Maxamus
                          • G-UNIT
                            • 949
                            I've heard that it fits, but not really sure.
                            I bought speedmaster hardware and so far i'm pleased with it.
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              All you need is some 062 piano wire for the steering.
                              I will send you a piece if you pay for Shipping.
                              www.rcraceboat.com
                              jwohlt5362@yahoo.com
