Stock outdrive design flaw! Fix it easily before you crash like mine!
  • MT-Tank
    • 14
    CRUNCH! I just found out what splintering fiberglass sounds like....
    The stock outdrive has a design flaw that is easily fixed. The control horn on the top of the outdrive is attached by a single screw. Remove this and you should find two small plastic pins that take the torque of the steering.
    I was running the BJ in open water, no collision, when I suddenly found that the boat would not straighten out after a turn. I killed the power but could not avoid a collision with the dock. Found that the control horn had twisted on the outdrive. Removed the horn and found two plastic pins had been sheared off. I repaired by running a screw through the horn, into one of the embedded pins. Learned how to repair fiberglass... Looks lousy...
    Recommended fix should take five minutes:
    Remove control horn. Remove one or both plastic pins. Drill through horn where pin was. Screw through horn into the hole that the pin previously fit into. I used a servo mounting screw.
    I can't believe that ProBoat skimped and used just one screw where two would have been obvious...
    Paul
  • rockwerks
    • Jul 2008
    • 772
    Those pins are there to protect the system from damage its not an over site
    an RC rock crawler lost in a sea of boat parts.........
    • MT-Tank
      • 14
      Poor design
      So the pins protect the servo gears. Great.
      But the twisted control horn, due to plastic pin failure, causes a crash that smashes the hull. Not great.
      I would have rather replaced the servo than do fiberglass repair.
      Anyway, those who still run the stock outdrive can decide for themselves which risk they would rather take.
      Respectfully,
      Paul
      • Eggy
        • Jun 2009
        • 152
        I did about the same when i where using the outdrive. Quite often the outdrive broke free of the mounting point. At slow speeds this was no problem but when doing close the 50Mph it was not a pretty sight. Also cost me a prop.
