well after abusing my blackjack on 6s for so long my flex shaft is finally worn to the point that it just spins inside the collet , even when tightened to the max.
i bought an octura flex shaft which is considerably longer which is required anyways to install the fullers hardware.
i decided to replace the motor collet with a new one from pro boat as well as the screw set which holds the flex shaft to the prop shaft just in front of the rudder.
my problem is i cant figure out how the flex shaft gets secured to the screw set . i tried to take out the old flex shaft from the screw set and i couldnt budge it.
is this thing welded in there or what? what is holding the flex shaft inside this metal collet?
any help guy would be very appreciated.
