Boat recommendations
  • batman53201
    • Oct 2017
    • 42
    #31
    Hey guys. What would be a good charger to buy. I want to be able to charge at a minimum of 4 batteries at once
    • MADRCER
      • Feb 2017
      • 751
      #32
      Originally posted by MADRCER
      I've got two nearly new 3s SMC True Spec Premium 90c 5200 packs with EC5 connectors that I might get rid of if you are interested. They have only been ran 3 times in my Veles pushing it well over 70mph before I had it dialed in like it is now. I Purchased them new at the end of October 2017. I'll take $75.00 shipped for the pair. If you are interested I can send pictures with voltage readings. They are like these linked below but mine are 5200mah.
      https://www.smc-racing.net/index.php...product_id=413
      Below are photos of my batteries with resistance numbers and cell voltage as we discussed by PM. The manufactured date is on inside of the box lid as well (10-16-17). They have been in storage mode for about a month. Also as we discussed 90c discharge packs will not damage your boat. Most people run at least 50c and higher packs. Lower C-rated packs will won't hold voltage under load as well and they will overheat under heavy amp draw leading to failure.
      • jim82
        • Jan 2013
        • 1358
        #33
        https://hobbyking.com/en_us/turnigy-...k-charger.html
        • MADRCER
          • Feb 2017
          • 751
          #34
          Jim above has a good economy model that would work....
          Unless you want to spend a lot of money on a power supplies and top of the line charger...The Hitec x4 would fit your needs as a decent entry level charger. It's not the fastest charger while charging 4-3cell and above packs but it will charge 4 packs at one time. Some like a charger that charges 2 packs, but it's capable of charging those two packs at higher amps and faster overall charging (if they need them charged really quick). Below is a link to the hitec x4
          https://www.amazon.com/X4-AC-Pro-Por...words=hitec+x4
          • batman53201
            • Oct 2017
            • 42
            #35
            After checking out this charger, I'm guessing that I will need to purchase more connectors in order to charge 4 at once. It comes with a bunch of different connectors, but only one of each. Which connector type would I need?
            • MADRCER
              • Feb 2017
              • 751
              #36
              Its cheaper to buy it at Tower Hobbies and use promo code 011V3 to get $20.00 off your order if you want to go that route. Below is what you will need.
              1 of these https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXGJSF
              3 of these (only 3 because it already comes with 1) https://www.towerhobbies.com/cgi-bin...?&I=LXAUAU&P=M
              4 of these http://graysonhobby.com/ec5-male-to-...oogle_shopping
              • batman53201
                • Oct 2017
                • 42
                #37
                Great. Thanks again.
                • MADRCER
                  • Feb 2017
                  • 751
                  #38
                  Dave your batteries have been shipped. Tracking number sent.
                  Thanks!
                  • batman53201
                    • Oct 2017
                    • 42
                    #39
                    thanks mark
                    • batman53201
                      • Oct 2017
                      • 42
                      #40
                      do you happen to have a current promo code? the one above doesn't work.
                      • MADRCER
                        • Feb 2017
                        • 751
                        #41
                        011V3 ($20 OFF $199.00 order)
                        • batman53201
                          • Oct 2017
                          • 42
                          #42
                          that's the one that I tried and it didn't work
                          is it a letter o, or number zero?
                          EDIT:NEVERMIND. I think I just had to register first.
                          • batman53201
                            • Oct 2017
                            • 42
                            #43
                            mission accomplished. I have everything ordered, except the boat.
                            4 new smc batteries (received)
                            2 used batteries from MADRCER (received)
                            2 PROPS from dashboata(received)
                            2 flex cables from kfxguy(received)
                            battery charger and accessory cables from tower hobbies(received)
                            connectors from grayson hobby(received)
                            when all that gets here, then I will go to my local hobbytown to order the boat.
                            hope I got everything I need
                            • batman53201
                              • Oct 2017
                              • 42
                              #44
                              Thanks. I got it to work after I registered with them.
                              I also received the batteries you sent. Thanks again
