Velos 36 - Balancing Act
  • mikiek
    • Apr 2017
    • 191
    I have been whining about my boat skipping over the water when I run it. In fact there are times when it is completely out of the water and I hear the motor screaming for the split second it does not get any resistance from the prop. If there is such a thing as running too dry this is it.
    I have been running with 4 3S packs. As you probably know there is very little room to slide them forward or back to adjust the CG.
    Today I adjusted the struts down 4mm. Took the boat out and I saw very little difference in the runs that I did.
    So the next plan was trying just 2 batteries and having more freedom to move them around. Although I am beginning to think differently, it seemed there was a weight problem. Not enough to hold the hull down. What that in mind I went with 2 6S packs as far forward as they will go. Unfortunately they won't slide under the deck.
    Now for the good news. Just watching it run, it was obvious that it was running better. It was lower to the water and seemed like it wanted to knife thru what little chop there was vs. skipping over it like before. The GPS went from an earlier 51mph to 54mph on just 2 out & backs.
    The bad news was I seemed to be losing signal with the boat at about the turn around point. I was fortunate to bring her back without having to paddle out and get her. Not sure what was going on. The batteries were still juiced so it should not have been the ESC cutoff. The boat was out maybe 1/4 mile so I don't think it was too far. I was able to goose the throttle a few times and get a little spurt of motor running. And then one time I pulled the trigger and she ran all the way in. Definitely time to call it a day.
    So I guess I'll continue experimenting with CG and see what works best. It does kinda stink that 4 batteries aren't working for me. I coulda bought a lot fewer batteries
    May your batteries never fail you...
    Mike
  • Prodrvr
    • Jul 2015
    • 701
    Originally posted by mikiek
    The bad news was I seemed to be losing signal with the boat at about the turn around point.The boat was out maybe 1/4 mile so I don't think it was too far
    Two questions: What radio are you using that you think 1/4 mile away isn't far?
    How do you see a tiny boat 1/4 mile away?
    • vinnyp
      • Mar 2017
      • 283
      I have not attempted to run mine that far away. 1/4 mile is a long way, as was said, you cant judge where it is or what direction it is heading at that distance. I keep mine reasonably close to me. I buzz the beach where it is deep enough to keep out of the sand but shallow enough for me to walk out and get it if I have to. Funny thing is that I have found a spot where the boat loses radio reception and just stops. Both of my boats do this in the same spot. Maybe some Bermuda triangle thing going on there, don't know for sure. In any case, I just walk further down on the beach to a spot where I can avoid that dead zone.
      • mikiek
        • Apr 2017
        • 191
        Vinny - This spot is across the water on the far shore and there are houses packed in. I'm wondering if maybe I hit a Wifi hot spot or something. The boat was running intermittently until I got 30-40 feet away, then it ran fine.
        Prodrvr - I am using the stock pistol transmitter. Still a Newb so maybe 1/4 is too far for these things. What I said I was basing off my RC sailboat experience. I can go twice that far with those transmitters. And no they're not Ham radios I have no problems seeing the boat at that distance - the yellow stands out well for me. As long as it is moving I don't see it being an issue. The only problem I have is like today when it stopped and started to drift. Then it's hard to know what direction it is pointed. Even then if I can bump the throttle and look for the rooster tail the direction is not hard to determine.
        Maybe I need to add some binos to my kit.
        Mike
        • iop65
          • Mar 2013
          • 367
          1/4 mile?
          you can't see what's in the water ,maybe some kids are swimming !!!
          • mikiek
            • Apr 2017
            • 191
            I hear some obvious concerns for safety here. Let me assure everyone safety is always on my mind. If I didn't think what I was doing was safe I WOULD NOT DO IT. As an example - besides the transmitter problem yesterday, the other reason I brought the boat in was due to the fact that some kids set out into the water on a surfboard. Could I have continued to do laps at some distance around them? Yes. Could I have done some out & backs at a distance away from them? Yes. What did I do? I took my boat off the water. The spot I run is a large protected cove with a marina at one end and me at the far end. If I see anything on the water - swimmer, jetski, boat - my boat comes in. Period.
            Now can we get back on topic?
            Mike
            • mikiek
              • Apr 2017
              • 191
              Last day off so I went out for a quick run this morning. Water was the smoothest I have seen yet - almost like glass until I get the boat out there. I'm sticking with the 2 6S packs. Yesterdays run I had them as forward as I could get them, today I started with them about 1" further back. The bow was definitely doing some ups & downs but the prop is still staying in the water nicely. Next I moved the packs forward again. That seems to be the sweet spot - at least for these 6S packs. The hull attack was very smooth, no ups or downs. For the most part the hull stayed perfectly level.
              Brought her back towards the boat ramp and let her float to cool off for a sec. When I started it back up - circles I could see a few pine needles hanging off the rudder but when I got her closer to the pier I could see one of the props was several inches behind the strut. Busted that shaft up at the motor. Guess I'm lucky it didn't come out all the way. I've seen a fitting that goes on the shaft up by the motor to prevent that. Don't remember where.
              So the day was over but I did improve on my speed - 54mph yesterday, 58mph today. I think I'll put the struts back to 0 next time. Also time to break out the OSE replacement shafts. And of course, batteries in storage mode.
              Mike
              • vinnyp
                • Mar 2017
                • 283
                mike,
                Good to hear your running better. I am hoping to run mine this weekend. Between working a lot and terrible weather, I have not had many chances to run it. As was suggested, I got a set of octurro x447's. I worked them but did not detongue them. We'll see what happens.
                I think these flex cable savers may be what you are looking for. The next time I order from OSE, I will include them as well.
                https://www.offshoreelectrics.com/pr...ex+Cable+Parts
                • MADRCER
                  • Feb 2017
                  • 751
                  The radio that comes with the Zelos 36 (all black version of the DX2E) runs out of range at around 800-1,000ft. However I have a couple of the DX2E radios with the orange stickers and they get more range. I have tested the two versions of the radios in my Zelos against the Impulse 31 v3 and the Geico 29 v3 and the Zelos radio doesn't get the range they do.
                  • mikiek
                    • Apr 2017
                    • 191
                    I was first thinking about upgrading. But I do agree with what others have said. I'm pushing the edge of the safe range. Kinda pointless to have the boat go any farther. Of course the flip side of that is it would be good to have a TX that I can trust to get me there & back.
                    They need a 'Home' mode like my drone. If they get out of signal range they turn around and go back to the takeoff spot.
                    Mike
                    • mikiek
                      • Apr 2017
                      • 191
                      I was able to go out with some of the members of Heart of Texas club today. Wow, what a difference running with some folks that know what they're doing! A good bunch of guys as well. We were out in Crosby Tx at a pond that appears to be dedicated to RC boating. A decent size, buoys at each end to mark a circuit, even an elevated driving area. Very nice! Conditions were outstanding - water was mostly smooth, light winds.
                      After a few tweaks to my strut angles, just barely angled up (yes up), I had the Zelos running very straight & smooth. First run - 2 6S - we tried moving the packs back to the stern as far as they would go. That caused to bow to bounce a bit and I ended up flipping the boat. Next I moved them forward as far as they would go and that did it. No more bow bouncing or hull skipping and I was able to keep the throttle down for most of the straights. Never been able to throttle down for more than a second or two. Of course I forgot to put the GPS in
                      When the 6S started to drain I switched to 4 3S just to see if I could get that working. Ended up with 2 all the way forward and 2 all the way back. GPS in this time and I peaked at 62mph By far my best speed
                      Probably the most fun was working those turns in the circuit at near full speed. The Zelos really hung in VERY tight and I was able to come out and quickly accelerate. This has not been happening at my spot where the turns have been sluggish.
                      Most of the guys there had boats they had built, but they seemed impressed with the Zelos, considering it was an off the shelf boat. Now if I can just get that performance at home.
                      My thanks to all that were there today...
                      Mike
                      • NativePaul
                        Greased Weasel
                        • 2760
                        Good times, I hope you go back and race with them.
                        I wish I had your eyes.
                        • vinnyp
                          • Mar 2017
                          • 283
                          Mike,
                          Great news that you are running well. 62 in stock form is nice. Are you running the stock props?
                          I hope to run mine tomorrow morning. I will post my results.
                          • fweasel
                            master of some
                            • Jul 2016
                            • 4288
                            FYI, when you crash, bring the boat back and have a quick look at the strut adjustment. On more than one occasion, I've flipped and knocked one of them out of wack. That reminds me, I need to disassemble mine and rough up the mating surface of the clamping point to provide a little more friction when the hardware is snugged down.
                            Vac-U-Tug Jr (13mph)
                            • mikiek
                              • Apr 2017
                              • 191
                              Paul - I am looking forward to running with them again. This was the first real "track" I've run on and I figured why it's seems so long at my local spot. At the site today you are standing at the half way mark on one of the straights. When I loop at home I am at one end so that turn at the other end is pretty far away.
                              Vinny - I was using a set of OSE CNC props. Wish I had thought to try out the stock props.
                              fweasel - you may have been spot on. I made a suggested strut adjustment before the first run and I know I had both struts on the same plane. We looked at it after the flip and it was obvious to them that one strut was now a little higher than the other. Turned out to be no more that 0.5mm off. Your point is well taken - a good inspection after any mishap is in order. As well as a possible adjustment so it doesn't happen again.
                              One thing they were all surprised at was the CG (at least on my boat) was very far forward. Even without batteries. That's why they had me try that first run with the packs at the rear. However they did see exactly what I have been experiencing, the hull skipping over the water and the props not in 100% contact. That's why the suggestion of struts up - to push the stern and the props into the water. I think most of my strut adjustments prior to today had been down to try to keep the bow a little wetter.
                              Regarding the forward CG - I gotta wonder if all the epoxy I put on the inside of the hull when I repaired the cracked hull may be affecting that.
                              Big take away today was what a difference a 1mm can make in performance. It was cool going thru that cycle of do a lap, bring it in and tweak it, repeat. Of course having all that experience there helped too.
                              Mike
