Now I understand "Puff"
  • REDLINE1
    • Jul 2016
    • 199
    here's a link to the steering cables. Of coarse there on backorder
    • mikiek
      • Apr 2017
      • 191
      Thanks REDLINE - just noticed today they are available. Ordered 2.
      May your batteries never fail you...
      Mike
      • mikiek
        • Apr 2017
        • 191
        Man I'm really getting nervous about plugging in some batteries this evening. Everything is in place but I don't have a warm fuzzy feeling. Fire extinguisher and garden hose will be at my side. Will be doing this outside in the driveway.
        Mike
        • vinnyp
          • Mar 2017
          • 283
          Good luck Mike. Hopefully, you puffed your last puff the last time.
          • Prodrvr
            • Jul 2015
            • 701
            This is from page 1 of the "that'll learn ya" file. One good expensive mistake usually won't happen twice.
            • mikiek
              • Apr 2017
              • 191
              At least not the same mistake
              Mike
              • mikiek
                • Apr 2017
                • 191
                Something I realized a little while ago. What is the purpose of the ESC on/off button?. Sounds obvious I know, however the ESCs smoked as soon as I plugged in the batteries. I never pressed the button to turn them on. Apparently the circuit is closed without pressing the button? Or is the button "downstream" from the ESCs? I would have expected battery, on/off, receiver, ESC, motor.
                Mike
                • fweasel
                  master of some
                  • Jul 2016
                  • 4288
                  #23
                  That's an interesting fact, but not one I'm willing to test out myself.
                  Vac-U-Tug Jr (13mph)
                  • mikiek
                    • Apr 2017
                    • 191
                    #24
                    Mike
                    • mikiek
                      • Apr 2017
                      • 191
                      #25
                      Fire extinguisher - check
                      Hose with sprayer - check
                      Safety glasses - check
                      Plugged in 1st battery - we're a go flight
                      Plugged in 2nd battery - the usual pop/spark in the connector (scared the bejezus out of me) - we're a go flight
                      Turn on transmitter - check
                      Power up boat - man it's been so long I forgot how - read instructions - CHECK!!!!!
                      Steering - check
                      Throttle - check
                      Power down. Had to baby sit tonight so didn't get to the water. Will sneak a few laps in the morning before work. Still need to program. I hope this won't be problematic. The instructions keep mentioning flashing lights & beeps. I see the flashing lights but I have yet to hear a beep. Hopefully it's not the same pitch as the tinnitus in my ears.
                      Can't say this ordeal is over quite yet but I will say I am grateful for all the help and support I have received in this forum! Don't know where I would be right now without you guys
                      Thank you!
                      Mike
                      • vinnyp
                        • Mar 2017
                        • 283
                        #26
                        Mike,
                        I got a little chuckle out of the way you told of your powering up procedure.
                        Great that all seems ok. Have a good run tomorrow.
                        • Tamelesstgr
                          • Jun 2014
                          • 1516
                          #27
                          Mike,
                          Always Always Always turn your transmitter on first before plugging in batteries. If something were to glitch and the transmitter was not on, you could instantly have two propellers spinning which can be very dangerous. Also, never turn off the transmitter before you have disconnected your packs for the same reason.
                          Ken
                          NEVER SATISFIED RACING
                          Fine Design 32 V-Hull 4082+6s
                          • mikiek
                            • Apr 2017
                            • 191
                            #28
                            Thanks for that Ken. I shoulda known. I have to do my sailboats in that sequence.
                            Mike
                            • TheShaughnessy
                              • 1431
                              #29
                              Thank you!
                              Man I had to lol after reading that. I put the connectors on a brand new car esc backwards once, fried it. It was race night and I wanted to race so i bought a new one from the shop only to have it go up in smoke during programming (that company no longer exist btw). Ever since then the pop/spark will give me a good jump if I'm not ready for it. I've also plugged in two batteries to each other instead of the esc, on more than one occasion sadly. Just thought I'd let you know you aren't the first one to screw up the wiring. It's expensive and discouraging but all this pain and suffering must mean there are brighter days ahead, ones that aren't lit by fire
                              I now follow a couple simple rule during battery hookups. 1 no talking, unless it's to your self about the colors of the wires. 2 check polarity twice and plug in once. The 2nd rule is a modification of measure twice cut once.
                              • TheShaughnessy
                                • 1431
                                #30
                                my best guess on the on off switches is that they are only rated to a certain voltage, first the switches fried, once that happened the circuit closed and took out the esc.
