After my 2nd outing I figured it was time to relube the flex shafts. While disassembling everything I have noticed that one of the stuffing tubes (the outer brass tube) is not perfectly straight. It's got a slight curve to it. Not bad but it is noticeable. I suppose that's why we have the flex cable. Can't think of an easy way to straighten the tube. Maybe it's no big deal?
Instructions say to look for water ejecting from the cooling system. Still haven't seen that. I do see water in the tubing. Is that good enough? No parts were particularly hot.
Instructions mention calibrating the transmitter. I understand how to, but why?
Same question on programming the ESC?
I have not yet started to make any adjustments yet and I'm still running with only 2 3S batteries for now. I would think prop adjustments would vary based on battery configuration - 2 3S vs 4 3S vs 2 6S. Do you guys usually stick to one battery configuration?
Lastly, when I flipped the boat on my first outing water got inside. I realize most of the electronics are waterproof but how about the batteries?
Thanks in advance...
