Stiletto outboard on 29" catamaran hull
  • Garrett
    • Mar 2012
    • 126
    Has anyone thought of, or tried taking a mystic/geico/blackjack 29" hull gutting it out, and running single or twin stiletto outboards? With the batteries up front, to counter the weight?
  • forescott
    Hopelessly Addicted to RC
    • 2686
    I ran a stiletto outboard on a sv-27. It ran ok, but a little squirrely. Too small of a hull I think.
    • Garrett
      • Mar 2012
      • 126
      I was thinking that the cat hull would have more surface area in the water vs a mono hull, and may run a little better.
      I was also thinking that the stiletto outboard could mount up to the mystic hull where the 4 strut bolts go, and eliminate the shaft underwater, and the offset rudder. but that's alot of if's...
      • stifflkd
        • 17
        I have a Aeromarine 29" Sprint Cat with Hyperformance drive and T600 outrunner. Runs fine straight but needs fins for turns. I opted for the Sprint Cat over the Mean Machine as the deck is cut out further up front making it easier to get to the batteries. Expect to make a lot of modifications at the transom for strength and getting the outdrive high enough so the prop is at the right height. Great setup for an outrunner.
        • lenny
          • Sep 2010
          • 4293
          No a mono has more surface area in the water vs a cat hull,
          That is why the cat hull rides on top of the water and likes lifter props.
          ? ONLY IF THEY WORK
          • Garrett
            • Mar 2012
            • 126
            But there's more planing surface in the water with a cat hull, vs a mono hull. The ride pad area on a mono is much smaller than that of a catamaran.
            • lenny
              • Sep 2010
              • 4293
              Nope,
              Do a search on it.
              ? ONLY IF THEY WORK
              • Garrett
                • Mar 2012
                • 126
                So a cat has more surface on top of the water than a mono?
                • Garrett
                  • Mar 2012
                  • 126
                  So we're on the same page, I'm operating a Spartan, and a Mystic. The Mystic seems to have more hull area on top of the water than the Spartan.
