ProBoat water jacket change to 90 deg nipples?
  • JimClark
    • 5907
    Anyone found any 90 degree nipples that will fit the proboat water jackets?
    Jim
    Billy Graham
  • stadiumyamaha
    • 1284
    Of you find some please let me know.
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    • JimClark
      • 5907
      might end up just buying a silicone water jacket so the tubes don't exit straight up
      Billy Graham
        • 8012
        Be prepared for a boat full of water. Every silicone jacket in our club boats leaked like a sieve after a short time, even with plenty of bathtub caulk around the edges. Better to plug the existing jacket holes and re-drill for the nipples below. That way you can put them in the right places - exit high on top, inlet as low as possible.
        http://www.offshoreelectrics.com/pro...prod=etti-a029
        • tryinotocrash
          • May 2012
          • 190
          I don't know what the thread is on the water jacket but check these out. Scroll down a bit and there are several 10-32 90 degree and swivel fittings. .http://www.mcmaster.com/#standard-ba...ttings/=if9hjn click on the brass fittings on the left and scroll down.
          Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
          • stadiumyamaha
            • 1284
            What size motor are you using? I've got a new Traxxas silicone water jacket you can have. Works well on the spartan 36mm motor.
            • JimClark
              • 5907
              36 mm diameter is what the proboat motors are
              Billy Graham
              • stadiumyamaha
                • 1284
                If you need it let me know.
                • JimClark
                  • 5907
                  Pm sent thanks stadiumyamaha
                  Sent from my MB611 using Tapatalk 2
                  Billy Graham
                  • roadrashracing
                    • 1462
                    could use these and tap the hole if need be:
                    • ray schrauwen
                      • 9471
                      90 degrees of water cooling
                      The holes are 4mm thread. Steve sells 90 degree fittings that fit http://www.offshoreelectrics.com/pro...prod=etti-a030
                      But, IMO it would be better to have the 5mm threaded Leopard 90* fittings, they will flow much much more water and be that much cooler.
                      The Chinese fittings are cheap but, they flow allot more than the above 4mm or even the brass 5mm threaded ones Steve sells (HRC type replacements)
                      I'm going back to the chinese fittings. When it's in the right position, add slow set epoxy or some CA to set them in place and no leaks.
                      After burning up 2 UL-1's at an event 2 weeks ago, I've been relearning cooling practices.
                      This 90* days and 90* water is challenging!!
                      Nortavlag Bulc
