PB BlackJack 29
  • Archer
    • Feb 2013
    • 12
    #91
    Diesel are you suggesting a 2s and a 3s in series?
    • lomdel
      • Nov 2008
      • 708
      #92
      Prepping for some runs later today...
      • lenny
        • Sep 2010
        • 4294
        #93
        Yes, For 5s running.
        But they need to be all the same, But the volts.
        ? ONLY IF THEY WORK
        • lomdel
          • Nov 2008
          • 708
          #94
          My BJ29 at full throttle yesterday. Awesome pic by my wife!
          • lomdel
            • Nov 2008
            • 708
            #95
            What is the best method to remove the flex shaft for re-grease without removing the whole strut?
            • ray schrauwen
              • 9472
              #96
              Use 2 wrenches to loosen the flex collet at the motor and the shaft slides out from the strut. Who told you you have to remove the strut? Take prop off first and nut. Should be no problem.
              • Archer
                • Feb 2013
                • 12
                #97
                Nice pic Lomdel ! How many S? And was that the stock prop. Also what do you think about the turning with the offset rudder.
                • lomdel
                  • Nov 2008
                  • 708
                  #98
                  Nothing stock about that BJ29. OSE upgrade Leopard motor and T180 ESC on 6S with Octura prop. Stock driveline parts, though. About 45mph I think... She turns on a dime!
                  • Archer
                    • Feb 2013
                    • 12
                    #99
                    With the rudder to one side mine seems to fight the prop one way and turn well the other. I have to let off the throttle to get it to turn anything but a large arc.
                    • rayzerdesigns
                      • Dec 2013
                      • 1228
                      #100
                      you don't need to run 6s for speeds in the 50s..stock speedo ul 1 motor x642 prop 2x 2s 5500mah 50c with no timing..for shorter runs I can crank timing up to 7degrees gps at 56mpg
                      • skeeler
                        • Jul 2007
                        • 198
                        #101
                        Originally posted by airman66285
                        It would be fantastic if Proboat offered a 36" MissGeico catamaran twin in the future - I would snatch one up in a second.
                        I second the suggestion of a 36" twin Miss Geico cat!!
                        I know these are old posts in an old thread, but I'd love to see ProBoat offer a 36-inch-ish Mystic-styled twin cat. I'd snap up one in either Blackjack or Miss Geico livery in a minute.
                        Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
                        '09 Miata.
                        Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
                        • lomdel
                          • Nov 2008
                          • 708
                          #102
                          Ready to roll!
