Velocity series by MiniCatRacing
  • Opedopy
    • Jul 2009
    • 17
    #61
    question wat radio system would be good for this boat? it will be my first boat.
    also wat metal prop works for the velocity mono? i wanna get all the parts before i order it.
    also does the esc have a lipo cutoff?
    • sailr
      • Nov 2007
      • 6924
      #62
      any 2 ch radio will work fine. Most boaters prefer the pistol style radio.
      We don't sell a metal prop for the velocity series. The carbon prop that comes with it works perfectly. You might want to order a couple of extras.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • GimpyGolden
        • Aug 2008
        • 36
        #63
        Sailr is right the stock carbon prop works great.
        If you want a metal prop the Octura X432 is what I have on mine, it is a direct bolt on and doesn't require drilling out as some have thought needed. The 3mm shaft size glass filled props that Steven sells here are also a good option.
        • Opedopy
          • Jul 2009
          • 17
          #64
          just ordered a black one and ill be running this at the river so the water wont be close to calm lol.
          i just need to find a radio i have a specktrum DX3r but i heard some range issues with boats?
          ohh and a battery wats the best bang for ure buck? i see alot of options lol just getting into lipo have only had lipos for about 2 weeks so far lol
          Ohh this will be my FIRST Boat had everything but boats. now i can say ive owned every kind of RC
          • GimpyGolden
            • Aug 2008
            • 36
            #65
            The Spektrum will be fine.
            By the time this boat would have any range issues with that radio you wouldn't see it well enough to run it. Just keep sure you get the antenna up out of the hull.
            As for the rough water, might not do so good. I ran mine yesterday with a good breeze and small waves and I flipped it more times than I would have liked.
            Don't get me wrong it's a great little boat, but it may not be big enough to play River Rescue. Better suited to a smaller pond on calmer days, it can handle a little chop but not much more than it's own wake at speed.
            • Opedopy
              • Jul 2009
              • 17
              #66
              alright if i run it at the river ill run it in the morning or late in the day when most the boats arnt out.
              i plan on getting the new proboat hypersport 48 so i can run in more chop and learn more about boats.
              will this batt work 3s 2200 25c?
              or do i need a 20c pack?
              • Opedopy
                • Jul 2009
                • 17
                #67
                got my mono today the black version. but its the hull seems to be scratched up on the front nose and some places on the sides. everything else is pretty nice and well put together. right now im waiting on the battery to come in. where do u sudjest mounting the esc? also i bought a novak smart-stop lipo cutoff. wat do u guys use to seal a hole in a boat? silicone?
                • GimpyGolden
                  • Aug 2008
                  • 36
                  #68
                  Glad to hear you got one.
                  I wouldn't worry about a few scratches, you'll never see em at 30mph.
                  I mounted my esc in front of the rudder servo, you'll need to trim the cooling line but just make sure you don't get any kinks. In this position it balances out nicely with the battery on one side and the electrics on the other. I mounted my receiver directly below the antenna.
                  I assume the whole is from the LED on the SmartStop. I would just use a little silicone or Shoe-Goo.
                  Have fun!
                  • Opedopy
                    • Jul 2009
                    • 17
                    #69
                    yea i might drill a little hole for the LED and put some silicone or sho-goo like u said. or just leave it. only thing holding me back is my battery hopefully they get here monday.
                    ill prolly put some stickers on this thing so i can see it better :)
                    so far so good on my first boat :P
                    i also noticed a few odd things like the motor and esc wires were all switched around.
                    • sailr
                      • Nov 2007
                      • 6924
                      #70
                      Amazing! I can't figure out how those scratches happen inside all that bubble wrap. I personally inspected that boat before sent. It was pristeen.
                      I like to mount the the esc up ahead of the battery on the left side. That's where it naturally likes to sit. If you can velcro it up under the deck, that helps protect it from any small amount of water that might get in the boat. Be SURE you don't kink any cooling lines!
                      You don't need a lipo cutoff with our esc. It's already programmed for lipo cutoff for 3S.
                      Mini Cat Racing USA
                      • sailr
                        • Nov 2007
                        • 6924
                        #71
                        There is no particular color code on the motor wires. They should be hooked up correctly. DON'T mess with 'em! If you already have, the motor may run backwards. If it does, just switch any two wires.
                        Have fun! It's an awesome little boat!
                        Mini Cat Racing USA
                        • sailr
                          • Nov 2007
                          • 6924
                          #72
                          Some bright yellow stickers will help, that's for sure!
                          Mini Cat Racing USA
                          • Diegoboy
                            • Mar 2007
                            • 7245
                            #73
                            Originally posted by wayn
                            Hi I tape down the transparent inner cover and just screw down the top, I put a washer on so the top won't crack. I also use a rhino 2150 , 20c lipo, and it really moves . I haven't got any floatation in it, I make sure the tape is secure.
                            Have fun it's a great boat
                            cheers wayn
                            That's exactly what I do, mine self rights and takes on water only through the drive line. (very little)
                            • sailr
                              • Nov 2007
                              • 6924
                              #74
                              Good to hear but don't make me say "I told you so" if the boat ever sinks for some reason! Flotation is quick and easy insurance. The tape inside could dislodge for some reason. If the hatch isn't taped, it's not going to self right as the hull fills with water and then ker-plunk.
                              Mini Cat Racing USA
                              • Opedopy
                                • Jul 2009
                                • 17
                                #75
                                heres some pics of the boat and wat i found on it
                                everything else was fine
                                should be fine right?
