Micro Hydro Floatation
  • wiskers
    • Feb 2011
    • 32
    I've read a few sad stories about precious boats visiting Davey Jones Locker never to return. So does anyone have any suggestions for floatation in a Micro Hydro. Type of material; how much; where to attach it and with what. Thanks for your help.
  • DyrtyByrd
    • May 2010
    • 146
    pool noodles, cut to shape, stick em with glue or just stuff them under the deck
    • CaptPJB
      • May 2010
      • 237
      Second the pool noodle, I got too impatient with my first Minicat rigger used cheap hatch tape, it was just going to be a "test run" I had put no floatation in and down she went. Naturally it was at the furthest point in the lake from me when it happened!
      Two lessons learned use good quality hatch tape and flotation.
      Peter
      • sailr
        • Nov 2007
        • 6927
        Yep, pool noodles are our recommendation also. Don't stuff it in there so tight that you split the deck seam! Be sure to cut and glue a small sliver under the hatch! People lose the hatches all the time!
        Use good hatch tape! We use hockey tape. Seems to stick the best. OSE sells it:
        http://www.offshoreelectrics.com/pro...rod=hatch-tape
        Mini Cat Racing USA
        www.minicatracingusa.com
        • martin
          • 2887
          What type of glue is suitable for sticking pool noodles. Thanks.
          • sailr
            • Nov 2007
            • 6927
            I've used medium CA, 5 minute epoxy, or silicone rubber. All work fine. Make the foam in the front/sides fit snug and you won't need to glue them!
            Mini Cat Racing USA
            • martin
              • 2887
              Thanks Sailr, Would only use glue on the hatch. Martin.
              • wiskers
                • Feb 2011
                • 32
                Great information. Never thought about pool noodles, that material is way more stable than styrofoam. Thanks that's way I'll go.
                • Meniscus
                  Refuse the box exists!
                  • Jul 2008
                  • 3225
                  It is important to note if you are stuffing pool noodles into the hull to make sure the cooling lines are not pinched.
                  Also, in addition to pool noodles, some of us also use pink refrigerator foam. Often you can pick this up for free at local sources. It is super dense, non-porous and doesn't soak up water as pool noodles sometimes can.
                  • SweetAccord
                    Speed Passion
                    • Oct 2007
                    • 1302
                    Good info thank you. I always wondered about using a 8lb fishing line (braided) and using epoxy and glue it to the hatch/hull instead so it's permanently attached. It would be lighter if you need to be as light as possible, and or can help with space if the hatch area is small.
                    • sailr
                      • Nov 2007
                      • 6927
                      what sort of business would have refrigerator foam? I've never heard of it.
                      Mini Cat Racing USA
                      • Basstronics
                        • Jun 2008
                        • 2345
                        If you get any small air packets they use for shipping material. Not the type you twist to snap.
                        • JimClark
                          • 5907
                          I used 2 part Urethane Pour Foam for mine really stiffened up the sponsons
                          Billy Graham
                          • TotalPackage
                            Banned
                            • 601
                            Thats how you do it. Yes the foam when done right will make that hull truly rigid . That how i did my 16th atlas. Jim I love your small scales they look so good.I used "REGULAR" expanding foam not the triple and i didnt do it all at once i used is sparingly in anticipation of expansion. We use this stuf in trunks when I do a car stereo job to help deaden the trunk. This stuff was strong enough to deform the trunk lid over the internal beams.It will bend steel!
                            • Meniscus
                              • Jul 2008
                              • 3225
                              I think they even sell a variation at Home Depot. I believe they use in commercial HVAC, restaurant refrigeration, etc. Danny has scavenged some for us several times in the past. I keep working off of the same pieces I have around. I'll see if I can get you a better definition of the stuff and perhaps some places to find it.
