Twisted off drive shaft
  • paddle
    • Aug 2011
    • 5
    I got a 27r a few weeks ago , great boat , hell of a blast to run . I decided to add a little more power with LIPO's , a 60 amp ECS , and a Grim racer prop 42 55 , it was crazy fast . I was in the second run when I was able to handle and added power and was full throttle . All was good until I twisted off the drive shaft , and lost the end of the shaft , my prop , prop driver and nut . My question is this , should I upgrade the shaft to something larger , or was it just a faulty shaft and just replace it . The shaft size is .150 now , if I did upgrade where would I find such a thing .
    Thanks for any help or suggestions
    http://www.offshoreelectrics.com/pro...od=ose-svcable
    • paddle
      • Aug 2011
      • 5
      Thank You , got it on order . It looks like what actually happened is the prop shaft broke away for the cable , maybe heat building up ( but it was greased ) or the solder joint was weak . Is this a common problem with the oem cable ?
      • paddle
        • Aug 2011
        • 5
        Recieved my order today , fast service .
        • jlr3rd1
          • 240
          i have had that problem now i silver solder my shafts :) they havent come apart since silver soldered.
          2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
