Prop question
  • recloosetrav
    • Jul 2009
    • 49
    Prop question
    I just purchased a grimracer 40-52/3 prop and balanced it and sharpened it and it cavitates like mad. I just upgraded from the stock prop and am only running 3300 nimh batts is it maybe not sharp enough?
  • mdodge01
    • Aug 2009
    • 2
    i have the same thing going on to but i have the UL-1 motor in it and running lipos if u find anything out please let me kno thanks
    • recloosetrav
      • Jul 2009
      • 49
      Did you sharpen it yourself or did you get it done by someone. This is my first time tweaking a prop on my own so maybe thats the issue.
      • 6S HYDRO
        • 1320
        The 3 blade's naturally cavitate more.
        • recloosetrav
          • Jul 2009
          • 49
          Right now if i don't give it the toss launch is wont grab just cavitates and than when i do launch it it is only half the speed as of stock
          • 6S HYDRO
            • 1320
            may i ask where you sharpened it? and it also must be balanced. but i must say that ive taken 40/52-3's right out of the package and had great performance- so maybe you did mess it up
            • scooterP
              • Jul 2009
              • 237
              Did you do anything to the back of the prop? Did you polish or create the edge using the backside?
              • recloosetrav
                • Jul 2009
                • 49
                no i left the other side as it came.
                • scooterP
                  • Jul 2009
                  • 237
                  I was just curious. I haven't been in the boating side of the rc to be an expert by any means. I'm running the 42x55 two blade and it is like night and day compared to the stock prop. I had read that doing any polishing or sharpening to the back of the prop could cause problems.
                  • 6S HYDRO
                    • 1320
                    Yes the 2blades just jump out of the water on the start.
                    • recloosetrav
                      • Jul 2009
                      • 49
                      so i know balancing causes vibration issues if it is off balance but would it cause cavitation? or is that more the sharpening side?
                      • 6S HYDRO
                        • 1320
                        Vibration can cause cavitation too
                        • mdodge01
                          • Aug 2009
                          • 2
                          Rcloos I don't touch that stuff the prop is stock but it cavitation from the start then gets up and flys
                          • domwilson
                            Moderator
                            • 4405
                            You might want to pm egneg. He might be able to help you.
                            http://forums.offshoreelectrics.com/member.php?u=786
                            Government Moto:
                            • egneg
                              • 4664
                              Can you post a couple of pictures of the prop? I don't have an SV but I have heard that many have had problems with that prop.
                              IMPBA 20481S D-12
