Flipped it today .....
  • bossgvr4
    • Jun 2009
    • 41
    I flipped the SV today and it ended up doing it's icerberg imitation before I could cast a line over the hardware and reel it back in.
    everything got dunked.
    Do I cut the shrink of my batts and air it out ?
    My Rx is treated with CorrosionX so that'll be OK
    Is my stock SV ESC cooked ?
    Is the Liposhield done for ?
    How about the motor ?
    I took the electronics and put them all in a Tupperware with the big silica gel (1/2 pound) I normally keep in my gunsafe.
    Any suggestions will be greatly appreciated !
    DaveC
  • domwilson
    Moderator
    • 4408
    It would probably be best to cut the shrink. Your ESC should be water proof. Don't know about the liposhield. Spray the motor with WD-40.
    Government Moto:
    • z400
      • 1311
      Im not sure at all how we on the forums can answer 99% of your questions.
      We can not test any of the electronics for you that are in your boat.
      you need to remove everything and let everything dry.
      Taken apart and under a light source preferably.
      To keep this from happening again, you need to put some control behind your finger and to me it sounds like you need to seal or reseal your hull.
      Z
      KBB34" Mono - Fast
      ToySport Triton- Not as fast
      • bossgvr4
        • Jun 2009
        • 41
        I'm not asking you guys to test things for me .... I'll do that once things dry out.
        What I'm ASKING is if anyone has dunked similar equipment and had success in using lipos, ESC, Liposhield after allowing time for the stuff to dry ?
        Everything is taken apart and in a Tupperware with 1/2 lb of Silica Gel Dessicant.
        Thanks for the condescending reply though ... much appreciated.
        • Doug Smock
          Moderator
          • 5272
          Tact
          Tact is careful consideration in dealing with others to avoid giving offense. Tact may also refer to:
          Tact (psychology), term used by B.F. Skinner
          Tact Meyers, a fictional character in the manga series Galaxy Angel
          TACT Records, Israeli record label
          En-Tact, 1990 album by The Shamen
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Doug Smock
            Moderator
            • 5272
            DaveC
            Hi Dave,
            Like Domwilson said,
            Yes, CAREFULY cut the shrink off of your cells and let them air out.
            I would open up the RX and let it air out even though you have it treated.
            The ESC should be fine.
            Let the LiPo sheild dry out and then test it.
            Spray out the motor and bearings real good with WD-40 and oil the bearings before you run it again.
            Taping the hatch down will go a long way in keeping your equipment dry in a rollover.
            Good luck,
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • bossgvr4
              • Jun 2009
              • 41
              Originally posted by D.Smock
              Hi Dave,
              Like Dromwilson said,
              Good luck,
              Doug
              Thanks for the valuable advice guys !
              • I used baby fingernail scissors and cut of the shrink. The connections don't show any signs of corrosion and there is no puffing.
              • Popped the Rx apart for more drying
              • Washed down the motor with WD-40 as soon as Domwilson sugested it
              • Will tweak my 3PM settings and not turn so tight in the future .....
              My silicon seal must not have been that good so this has taught me that hatch tape is my friend.
              Thanks,
              DaveC
              • Jeff Wohlt
                • Jan 2008
                • 2716
                I love my aircompressor! Everyone should have one. Blower nozzle really get water out from areas you can't see. Then let it dry out for a couple days before powering up. Some alos use a blow dryer to begin the drying process.
                www.rcraceboat.com
                [email protected]
                • line6
                  • Aug 2008
                  • 478
                  Tape is your friend. $3.00 roll of tape $300+ in a boat you do the math.
                  • bossgvr4
                    • Jun 2009
                    • 41
                    Update ..... the only question mark is the lipos this morning.
                    • Used my Airbrush compressor to 'blow' out as much as I could last night.
                    Tested all the electronics this morning with a 6-Cel NiMH pack. Seems like it's all OK.
                    Will let the Lipos dry til Wed before trying them out again.
                    • Tape is my friend ... Tape is my friend ... Tape is my friend ... Tape is my friend ... Tape is my friend ... Tape is my friend ... Tape is my friend ... Tape is my friend ... Tape is my friend ... Tape is my friend ...
                    • bossgvr4
                      • Jun 2009
                      • 41
                      photo's before biting it !
                      • Doug Smock
                        Moderator
                        • 5272
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • AZpdljumper
                          • Apr 2009
                          • 90
                          Looks good Boss. These things kick ass.
                          SV 27 , Mean Machine, Prince 26,Vac-U-Pickle
