So I have decided to sell my Hammer that I just put a new ESC in because I found an Excellent deal on Used SV27 on eBay. Bought it and now have it in hand. Looks like the guy I bought it from didn't run it very much at all, and looks to be in good condition, albeit a bit dirty and some of the mounts are slightly corroded, trim tabs, starboard turn fin and drive shift, pretty much all the mounts at the back.
What is the best way to clean the inside of the hull? Looks like there might be a bit of mildew (or it might be grease) small black spot by the motor mount and the cowl has a couple as well. It has a weird smell to it, not electric and not really mildew, not sure could be fiberglass. I was thinking of using a diluted bleach solution to make sure if it is mildew that I kill it and get it clean. To clean the mounts I was planning on sanding the corrosion off, or should I just replace them? I am getting the new trim tab adjusters, antennae mount and latch kit to replace the stock stuff. Also going to get some new props (not exactly sure which ones yet). I am also planning on replacing the tubing with aquarium air tubing for use with the new water pickup on the trim tab adjusters.
Last thing, I know how to clean a brushed motor, but what about the brushless in the SV?
Thanks for any pointers.
