why does my boat pull
  • jlr3rd1
    • 240
    ok when running a left hand prop, at full throttle the boat PULLS HARD to the right? so when using a right hand prop , the boat want s to go HARD to the left x/440 prop??? after about 30 feet it will spin out if you dont let off the throttle, any ideals?? running a cf 45 right hand prop and 7 cell s 8.4 electrifly 3600 nimh batts?
    2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
  • Christaphason
    • Jun 2009
    • 104
    Does it pull too hard to adjust the steering trim on the remote control?
    • domwilson
      Moderator
      • 4408
      Where are your batteries placed? Do you have a smaller prop to test with? Do you have any pics of your setup?
      Government Moto:
      • jlr3rd1
        • 240
        YES when it turns it turns!!!!! i mean you cant do anything??
        • jlr3rd1
          • 240
          sorry here is pic s of the batt.s , plus i also have a 3 ounce weight in front of the motor as well as the 4 cell pack thats runs the bec?? and no other props yet
          • Raydee
            • May 2007
            • 1603
            Nevermind, I see that it is a carbon prop.
            Team Liquid Dash
            • jlr3rd1
              • 240
              really , no none of them have been? with metal props the same??
              • Raydee
                • May 2007
                • 1603
                Is that prop all beat and nicked up??
                Team Liquid Dash
                • domwilson
                  Moderator
                  • 4408
                  Is the stinger flat? It looks angled downward. On my own SV27 it like to run with 0 degrees angle.
                  Government Moto:
                  • jlr3rd1
                    • 240
                    no nicks ?? stinger , are you talking bout the shaft the prop mounts to??? if so looks angled down to me to??? would that cause the pulling??
                    • domwilson
                      Moderator
                      • 4408
                      That is the blue shaft that the prop shaft runs thru. With it angled down that would cause the boat to run wet. Considering the other factors, such as the weight added to the front and the batteries moved forward, it may be a problem. I don't know for sure if it would cause the steering issue, but it is a start. Try raising it till it is flat with the bottom of the boat. See if that helps.
                      Government Moto:
                      • domwilson
                        Moderator
                        • 4408
                        Try bending those trim tabs so they are flat with the bottom of the boat. They look angled down too far also.
                        Government Moto:
                        • jlr3rd1
                          • 240
                          ok awesome:) thanks for the help , i need all the help i can get lol. i will make adjustments and try again and again!!! thanks again and will let you all what happens also removed the 3 ounce weight???
                          • domwilson
                            Moderator
                            • 4408
                            Try it first with the weight. If it is ok with you, leave it in. If it runs too wet take it out. Play with the battery locations as well. It may help you some as well.
                            Government Moto:
                            • jlr3rd1
                              • 240
                              ok will do that and see what happens:)
